setting up a new home theater system
wakey2
wakey2 Posts: 6
Hi All. This may seem basic but whatever - here goes. I am awaiting delivery of a new samsung 46 lcd/led tv tomorrow. I started to set up my new system with my old tv tyonight to just get ready. Have a yamaha rx 465 receiver and polk speakers. I hooked up temporarily the scientifc atlanta cable box from the HDMI connection directly to the receiver to get the sound but could not get any video from component or composite line to tv. I CAN get picture only from the composite video jack on the cable box directly to the tv.
My question is this: WHY? I thought everything can go thru the receiver. will that only work when i hook up my hdtv and run an hdmi cable from the receiver to the tv or will that be a problem too. Why no picture thru the receiver. Is it the tv? any ideas from you tecnos out there??????????
  • howardru
    howardru Posts: 26
    edited February 2010
    Basic questions not answered here include...
    ....Did you configure the cable box to output via the HDMI port and with the proper resolution- 720P, 1080i or 1080P?
    Did you slect the correct HDMI video input on the TV as a source?
    AUDIO
    Receiver - Onkyo TX-NR709
    Main L/R - Polk VM30 (Hi WAF)
    Center - Polk VM20
    Surr L/R Side Yamaha Inwall
    Surr L/R Rear - Yamaha NS-IW660 InWall
    Height: Dolby Prologic IIZ - Bose 161
    Sub- Polk DSW Pro 600
    VIDEO
    T.V.- 55" Samsung LED UN55B8000 240Hz
    Tivo HD w/1TB External Storage
    Blue-Ray- Playstation 3 Slim - 250GB
    Gaming - PS3 & Nintendo Wii
    Power - Panamax M5300-PM
    CONNECTIVITY
    Network - 8 Port GbE@ 3 x 802.11abg APs
  • Knucklehead
    Knucklehead Posts: 3,602
    I believe your AVR passes audio only....no video.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • howardru
    howardru Posts: 26
    AUDIO
    Center - Polk VM20
    VIDEO
    CONNECTIVITY
  • wakey2
    wakey2 Posts: 6
    thanks for the responses. Fuyrther questions. what do you mean the avr only passes audio. wont it pass video once I hook up an HDMI cable to my new tv. wont the hdmi cable pass along the audio and video connection? and when i hook up a blue ray player by hdmi to the receiver wont that pass along the video to the tv as well?
  • seeclear
    seeclear Posts: 1,244
    I'm not familiar at all with your receiver, but some will only output what the input is. IOW, HDMI in has to go out to the set via HDMI also, component in from the box has to go out to the set via component, etc. The receiver can't convert the signal from one type of input to another type of output, like HDMI in to composite (or component) out, they basically just pass it through without processing. FWIW
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
