Question about my HT
Im thinking about buying an amp just for my rears, so I can push the fronts more. Would my Front stage improve dramatically from this??
Thanks,
Thanks,
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Post edited by bdtae5656 on
I have to say this is a guess, but I would say that it would improve, but probably not enough to really hear it. I would go the other way and get a good 2 ch amp for the fronts, and let the 5 ch handle the rest. See what others have to say though as I said I'm just guessing.
Depends what amp you're looking at for the rears... if you want to go cheaper, maybe a UPA-2 if you want to stay Emo, then yeah, put the UPA-2 in the back.
If you want to stay with the XPAs, then get an XPA-2 and use that for your mains.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks for the input....Im sort of lost on what I should doTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Wait.... you've got a 5.1 setup? If you do, then i wouldn't bother changing anything on the amplification stage. IF you do wish to change just because, then i would suggest an XPA-2 for the fronts, and use the XPA-5 for the rears and have two channels open for a future 7.1 setup, OR sell the XPA-5 and get an XPA-3 in an attempt to recoup some of your investment.
But that XPA-5 should be just fine for HT duties. Are you feeling like something is lacking?
Sorry... i didn't realize that you had a 5.1 separates setup.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
That's the conventional approach. -
I have an XPA-5 and a Sunfire Cinema Grand powering a full LSI system, the only difference is I'm running 15's up front.
I've tried this several ways, Bi-amping the fronts with the rears on the other amp, the front and center on one amp and the rears on the other, and all channels off 1 amp.
Even though the 2 amps have different sonic signatures I still didn't see a large enough difference when running the fronts off just one amp. That being said it was a plus to have the fronts and center on the same amp, it sounded more cohesive than when powering the front and center on 2 separate amps.
Since I didn't see much of a benefit from having the fronts by themselves, I'd have to recommend keeping all the channels on one amp.
Jimmy -
Jimmy
Not lacking...I guess just expecting too much from the front stage. The rears work great off of the Emo. I dont usually turn my HK pass 54-55, maybe I should turn it up more while watching movies.
Yes i've got a 5.1....I wanted to turn my HT into a 7.1...but must new releases arent 7.1 yetTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
