SVC vs DVC on the SR subs?
![cruisedave](https://w8.vanillicon.com/8eb8687a168319c8589c1f722d0ab83a_100.png)
cruisedave
Hello everyone. Anybody have any thoughts on the SVC vs the DVC performance and sound? I'm looking at 1 SR 124, in the polk spec enclosure (sealed, 12") and the deals on Ebay seem to be for the SVC. I'll be powering it with the polk PA 600.1. Just not sure if the performance/wiring options of the DVC justifies paying close to retail price for it.
Thanks!
Thanks!
Post edited by cruisedave on
The pa600.1 will give you 300 watts at 4ohm and 400rms at 2ohm. Get the SR dvc. Sealed is good.
That's what I was thinking. Or I could get 2 of the MM1240 or 1040 DVC's with that amp, and it should push them pretty well, too, and I might get a lot more sound. I have not heard either the SR's or the MM's and there is no shop anywhere near me where I can demo them, so I am not sure of the difference in sound quality of the MM's vs the SR's. I do tend to like quality sound vs rivet-rattling bass, though. Any thoughts?
