Need new Source
MANSKITO
MANSKITO Posts: 295
edited February 2010 in Electronics
So I've just ordered an external DAC/head phone amp (the maverick audio D1 DAC) by the advice of people on the heard-fi forums. And I will soon be ordering some sennheiser HD600s/650s not sure which yet, I will soon have a chance to give both of them a listen and will make my decision then. At that point my weakest link in my chain will be my source.(currently I m using a PC and lossless audio not the best choice I know) I'm very excited at this point because finally it seems that a Mid-fi to Hi-fi system will finally be in my reach, and i could use all the advice I can get.
My budget is maybe $200 or at most $300. At this point I m thinking I should go with a digital transport of some kind because I already will have an external DAC.
But at this point the only experience I have with CD players is the one i bought from good will, Pioneer PD 5010 for like $7. I really have no Idea what I'm looking for and have no real way to give anything of this nature a listen on gear that is even remotely similar to mine.(most Hi-Fi shops ignore head phones). What do you guys think? I will basically be buying of the advice you guys give me because again I have no real way of listening to gear of this nature and how it relates to play back by head-phones. If at all possible at my budget I would like to get SACD play back because from what I have read around hear that is pretty much the best digital format. But if not I would be fine with a super awesome CD player.
Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s :D
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty
Post edited by MANSKITO on
  • ben62670
    ben62670 Posts: 15,969
    Look for a Denon 2900 used.
    Ben
    Ben
  • MANSKITO
    MANSKITO Posts: 295
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • bikerboy
    bikerboy Posts: 1,217
    Get a HiFace usb-> spdif and you are set. It can be ordered with bnc if needed.
    http://www.tweekgeek.com/_e/Portable_Computer_Audio/product/HiFace/HiFace.htm
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
  • MANSKITO
    MANSKITO Posts: 295
    bikerboy wrote: »
    Thanks man but I m going to be using the spdif out of my sound card to my external DAC I was looking for a suggestion for a nice CD/SACD player or a nice CD/SACD digital transport that would work well with my Headphones and DAC/amp.
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • steveinaz
    steveinaz Posts: 19,537
    Sony is always a great choice for a high-value player.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    ben62670 wrote: »
    Ben
    +1
    I'm using a Denon 2910 as my source...and it sounds great even by itself. Things sound even better when I run it through my DAC though.:)
    It has SACD decoding, as well as HDCD decoding, plus DVD/DVD-A playback...plus just about any other type of disc you can throw at it(other than Blu-rays).
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
