RT Setup advice...
polkanddie
I am running cs1000p center rt1000 fronts and rt600 rears. all seperate amps. If you look at my sig. I am seriously considering trying to find some rt800s for the front... after i got rid of my Eosone rsf600's i really miss the midrange. I also was thinking of switching the rears to rt55s...if i can find some... suggestions?
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
Onkyo tx sr 503
SUB(DIY)
Post edited by polkanddie on
I am a big RT fan. I have two Ht systems I run. One is Lsi and the other RT's. I have two sets of RT800's running next to each other using the A/B configuration and they are more musical than the RT1000's or Rt2000's. They have better mid range. They will not be as strong in the bass but that is what a sub is for. I have in the past stacked a RT55 on top of the Rt800 and that was also a great sound. You have a great center but the other speakers such as the RT1000 and RT600 are weaker in the mids. I would swap out the RT1000 for the RT800 and lose the RT600's for RT55's or Rt F/X500's. It would be a major improvement. Good luck.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
