will the Monitors be an upgrade for me?
david118383
I'm currently using Klipsch Synergys: a pair of F-1s, SC-1, and SS-1s. They were given to me a while ago, but I've never honestly felt they were all that great. I'm thinking about buying the Monitor 60s, Monitor 30s, and CS2 from Newegg. Would they be much of an upgrade from my Klipsch speakers?
Also, is there much of a difference between the Monitor 60s and 70s? I'm also using a Pioneer 1018ah-k. Is it powerful enough to push these speakers?
Post edited by david118383 on
david118383 wrote: »I'm currently using Klipsch Synergys: a pair of F-1s, SC-1, and SS-1s. They were given to me a while ago, but I've never honestly felt they were all that great. I'm thinking about buying the Monitor 60s, Monitor 30s, and CS2 from Newegg. Would they be much of an upgrade from my Klipsch speakers?
Maybe ( I would say so) depends on what you like in a speaker, I can tell you that the Klipsch are a good bit brighter then the polks.
you would be fine using the Klipsch synergys are surrounds don't buy the monitor 30s. The 60s and CS2 are a good bet.
For HT the 60s vs 70s really won't make much of a difference, if its for music I would say got for the 70s.Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
I would consider the Monitors an upgrade of the Klipsch's, but that is just my $.02. I have the Monitor 70's and IMHO they are about as good as it gets for a HT speaker in their price range. They do surprising well in 2 ch with a good amp and a buffer as I found out last weekend at the Seattle mini meet. The 60's are on sale at Newegg for $119.00 w/free shipping. Promo code EMCYNNP26. The 70's are going for $229, is it worth the extra $100, don't know, but I love mine. Good luck and welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
WELCOME TO CLUB POLK!
Yes the Pioneer 1018 should do a very nice job pushing any Polk M tower! That was very similar to the ENTRY Elite model before they cheaped it out with the new 1019.
cnh
Welcome to Club Polk
I have cs2, 70s front, and m40s for surround with psw 505. Running it with the 1019ah-k and and sounds fantastic for everything I use it for. Especially getting everything above new for less than $1250. You shouldn't have any problems running the monitors from experience. Newegg runs deals on the 70s down to around $175 but back up to $220s now though. Ive heard both the 60s and 70s and agree that there might not be a noticable difference all the time but I love my 70s so far. Could save the extra money and put it toward a good sub. Good luck!"C-A-T-S CATS CATS CATS"
Receiver- Pioneer Elite SC-37 :biggrin:
Surrounds- Polk Audio Monitor 40
Back Surrounds - Polk Audio Monitor 40 Series II
Sub- Polk Audio PSW505
T.V.- 55" Samsung 240 Hz LED UN55B8000 :biggrin:
Blu-Ray- 120 GB Slimline PS3 -
Hey Polknewby...
Don't understand your post?
OK, I got it you're responding to the Original Poster..and my remark about the Pioneer AVR....
Nonetheless, if you check the specs you'll see the 1018 has the superior amp section and pre-outs.
BTW...thought your pics of your new system were great!
Hey Polknewby...
cnh
Oh I agree with you about the amp and pre-outs. I was saying that everything sounded good with what I was running mine with; so using the 1018 should have no trouble at all especially if it is going to be hooked up with an amp. I started off with my tv and then the avr. I wish I had read more about the importance of pre-outs (kinda new to amps and what not) and gone with something a little different. Ill just have to use that avr for my bedroom when I start to build another HT and get a new avr for my main..:D And thanks for the remarks on the pics!"C-A-T-S CATS CATS CATS"
If I had a dollar for everytime I heard that, lol. That's why we "push" AVR's that have pre outs, whether you think you will need them or not, it is always a good option to have. Don't sweat it, you can get any number of AVR's that have pre outs for a good price in the used market.
-JeffHT Rig
Blu-Ray- 80 GB PS3
if I was going to look for a new avr to replace or upgrade...what would be good to run what I have set up right now? wouldn't really be looking to spend more than 700 tops (not sure how much amps are but ideally avr and amp for about that would be great). read some on the onkyo 707 and have seen where, I think its the pioneer elite model 21 (newer version is the model 23) runs less than 500 on the net and have seen the same for the onkyo..or should I be looking for others?? also what amp would you suggest and how much do they usually run?? Thanks!"C-A-T-S CATS CATS CATS"
its the vsx-21txh and the vsx-23txh.."C-A-T-S CATS CATS CATS"
If you are looking, then you need new, and there is really only 1 brand to get.
The Monitors I have are fantastic.
If I were to buy over again, I would step up to the 70's ( or any other series above the Monitor's )( I do love my Monitor 60's, but the 70's have to have even a bit more wow), keep the CS2 and the 40's ( a bit overkill on surrounds, but what the hey )( 30's would be fine, or wall speakers, another consideration for surrounds ). I would also step up to a sub with a remote. The PSW10 is just fine, but needs adjusting from song to video, or sometimes song to song or video to video, and a remote would be better is all.
Too, depends what you have driving your speakers too, as I went cheap and similar, and got a Sony to match my other stuff ( tv, dvd, vcr and eventual ps3 ). I should have gone Denon all the way. I bi-amped, and am just blown away, but do feel the limitations, and the limitations are entirely my Sony receiver. Still, my Sony does do ok, considering I paid half of what I would have paid for the labeled amperage I was seeking. However, I was advised by these fine people here, that the labeled amperage is a bogus number depending on mfg to mfg to keep like measure, ( you can only compare Sony amperage to other Sony amperage and so on ) which makes complete sense, kind of like tire wear numbers ( treadwear numbers ). Hope this helps, and may you buy any Polk Audio piece, and you will never buy anything else.Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar
