Adcom AVR/AMP
acmf74
acmf74 Posts: 937
edited February 2010 in Electronics
I am currently almost done with my HT set-up but have a question. My AVR is rated 265 wpc @ 4ohms. Would I see any difference if I add a Adcom GFA-555 that is rated @ 350 wpc @ 4ohms?
Front speakers are LSi15s...
Thanks,
Post edited by acmf74 on
  • ViperZ
    ViperZ Posts: 2,046
    Your receiver is usually rated with 2 channels driven or with some other constraints. Most of the good amps are rated with all channels driven.
    When you add an amp, you remove the load/strain from receiver amps (so the center and surrounds will get more juice). At the same time, you give true rated amp power to the mains.
    That amp is a great choice.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • jinjuku
    jinjuku Posts: 1,523
    Besides a bit more head room I doubt it will be a difference that you could tell at reasonable listening levels.
    If it's 265 watts continuous at 4 ohm that is pretty beefy. Even my Adcom 5503 at ~350w/4 ohm is most likely over kill. But I never let that stop me before.
    Remember for a 3db gain in output you have to double your amplifier power.
  • thuffman03
    thuffman03 Posts: 1,325
    265 watts into 4 ohm is pretty good for an AVR. I don't think it will be any louder but you might get better sound out of the seperate amp. Though you might hear no difference.
    Though I prefer to use seperate amp/preamp setups.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    heiney9 Posts: 25,497
    The Adcom GFR-700 HT receiver is an excellent unit. I'd say hold off on the external amp until you have some seat time with the GFR-700. It's a powerhouse receiver and you may find it does fine w/o external amplification. If not, then add an amp to run your fronts and let the receiver run the rest.
  • KASR
    KASR Posts: 450
    I agree with Heiney - the GFP700 will be able to hold it's own just fine....but the triple nickel is a great amp and if you get it, you'll end up having it forever! Those things are rock solid!
    I agree heiney9 is right. And KASR is also on the mark.
    Among other things I have an Adcom 555 and those things can handle 'almost' anything and last forever...they're almost military grade!
    cnh
