Kenwood C-1 pre-amp subsonic filter
gwh
gwh Posts: 1,451
edited February 2010 in Electronics
Does anyone know at what frequency it begins to filter?
Thanks!
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
    heiney9 Posts: 25,437
    I would guess since it's subsonic probably anything below 20Hz. It's designed to eliminate the low frequency rumble a TT could cause. If your not running a TT, then you won;t need to use it. If you are running a TT just leave it engaged, you're not cutting out any type of frequency that you want to hear..........or feel.
    EDIT: TT rumble can't be heard, but it can damage woofers. Many times you can see the woofs vibrating violently...........that's subsonic. Where exactly it's produced in the TT I don;t recall, but that's the only component that can produce something like that and it's exactly what a subsonic filter was designed to eliminate.
  • John30_30
    John30_30 Posts: 1,024
    The Service Manual for the C-2 says:
    Filter:
    Subsonic.................18Hz, 12 DB/Octave
    dunno if that's relevant, or if they're the same layout either.
  • Fongolio
    Fongolio Posts: 3,516
    heiney9 wrote: »
    I had a guy in a high end stereo shop demo that to me. With just a very high end table spinning and no record on, with the volume at about 1/2 the woofers appeared to be pounding but no sound could be heard. Then he turned on the subsonic flilter and they were perfectly still. My Pro-ject emits very little subsonic so the same test at home had not nearly as dramatic results.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • gwh
    gwh Posts: 1,451
    Thanks for the info.
    Was thinking about using it up stream on a passive sub.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
