SDA Compact Reference Speaker
Hal Brian
Hal Brian Posts: 2
edited February 2010 in Vintage Speakers
I would like to hook a pair of these up to a Hovland Saphire amp, which uses EL 34 tubes, and is a hybrid design. I am a newbie and understand that because of the crosstalk cable, the amp speaker outputs must have a common ground. I believe my amp has this, as most do. Any danger that anyone can see here to the amp? Many thx....this is my first post on this site.
Hal
Post edited by Hal Brian on
  • ben62670
    ben62670 Posts: 15,969
    Welcome to Club Polk. If you have a multimeter check for continuity between the speaker grounds on the amp. If it reads near no resistance you can safely use that amp.
    Ben
    Ben
  • Hal Brian
    Hal Brian Posts: 2
    Thank you very much......will do.....
