Replacement Driver
sir_lagzalot
Dumb question I know, but can I use a MW6502 in my Monitor 10b?
****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
Projector Epson 8700 UB
BLU-RAY Sony BDP-S1000ES
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Bellari VP 130 Phono Pre
Grant Fidelity Tube DAC-09
Sirius Stiletto 2
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Sirius Stiletto 2
Post edited by sir_lagzalot on
No, but you can use a MW6500, MW6600x, MW6501, MW6503, and either the 6511 or 6510 (can't remember which is 8 ohms).
For best results, use the 8 ohm driver that matches your other three. -
JohnLocke88 wrote: »No, but you can use a MW6500, MW6600x, MW6501, MW6503, and either the 6511 or 6510 (can't remember which is 8 ohms).
For best results, use the 8 ohm driver that matches your other three.****Home Theater****
Integra DHC-40.1
Rotel RMB-1075
Fronts 265-RT
Center 265-RT
Rears 65-RT
Sub BIC H-100
****VIDEO****
****2-Channel****
Magnepan SMGa
Sub ED A3-250
AMC 3100a
TT Music Hall 2.2
Sirius Stiletto 2 -
What is the problem if someone used the MW6502
The crossover was designed for the original driver specifications and when you change the driver characteristics, you will change the load presented to the crossover. This will impact the sound. It will not sound like the way Polk originally designed them to sound.
I am sure the more knowledgeable members will chime in regarding this issue. -
That's basically the way I understand it too.
