I feel like an idiot - Don't buy Pulstar Pulse Plugs
thsmith
thsmith Posts: 6,082
edited February 2011 in The Clubhouse
July 2008 I had a 100K service performed on my 2001 Ford Expedition 5.4L.
Gas was still pretty high at that point and the mechanic told me about these new plugs that would help with gas milage. Now before you start slamming me I have been around motors all my life and NEVER buy into this kind of crap but this day I had a lapse of judgement and said ok.
Well, 19 months later and about 18K miles I have a burned piston.
My NEW mechanic said he had never heard of them but you should stick with OEM plugs, which I already knew(stupid again).
I have searched to find if others have had a problem with these plugs and have not found anything.
Just be aware that it seems they caused my problem.
That motor should have seem over 200K easily.
Oh, and there goes my audio upgrades for a while, still kicking my self.
Post edited by thsmith on
  • shadowofnight
    shadowofnight Posts: 2,735
    edited February 2010
    If you stayed with the exact same heat range plug it should not have been a factor with your burnt piston. Check to see if the old mechanic installed the correct plug for your application.
    The first rule of Fight Club is you don't talk about Fight Club
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I feel something coming back and bitting the old Mechanic if he or she put a hotter plug in.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • thsmith
    That is what my NEW mechanic is checking for me but since OLD mechanic has closed his business I doubt there is anything that can be done.
    He showed me the burnt piston and crack using a Snap on cameria that goes into the plug hole.
  • Polkersince85
    Polkersince85 Posts: 2,883
    Timing and lean air/fuel may have more to do with it than plugs, provided they were not so hot they hit the piston.
  • thsmith
    No check engine lights or rough running untill all of the sudden there was a big time miss.
  • raidersrule76
    raidersrule76 Posts: 471
    That sucks bro!!!! I have a 01 F-150 with about 190000 on it and have had no problems. I had the plugs replaced with about 110,000 and used the autolite factory specs and it seems to be working well so far. Oh I guess reading this its about time to to replace them again. Good luck with the repairs.
    Mark
    Sig to be updated after dealing with the insurance company:(:(:(
  • thsmith
    Yeah, it just makes me sick. I know better than buy into that kind of crap.
    Oh well, thats how it goes.
    Going to put in a Ford reman and move on.
  • disneyjoe7
    I always liked GM plugs for GM, Ford plugs for Ford, **** plugs for ****, other words don't mix plug to different engines. NGK for ****, Autolite for Ford, ACDelco for GM they just work better that way. Just my $.02
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    pitdogg2 Posts: 27,072
    thsmith wrote: »
    So what was the plug? You should at least give us that. Brand and type my friend
    sorry didn't read the fine print:)
    It’s called a pulse plug – and here’s why its technology should be in your engine.
    Until now, every gallon of gas you bought was ignited by a simple spark plug- an outdated technology that has barely changed in 100 years. But now you can change to a new eco-friendly pulse plug that uses an advanced technology to make every drop of gas burn better and cleaner.
    Here’s how it works: Electrical energy from the engine’s ignition coil is stored in the built-in capacitor. At the exact moment needed, that energy is released in an amazingly powerful and quick (two nanosecond) high-energy pulse.
    The result: The improved combustion efficiency burns fuel sooner and more effectively, which equals improved mpg, less CO2 based emissions, and better overall drivability. Even the green get greener! For example, in this EPA US06 fuel consumption lab test, even the icon of fuel economy and eco-friendliness- the Toyota Prius- saw notable improvements in mpg.
    This new technology is based on plasma research supported by the world famous Sandia National Laboratories – and yes, that’s definitely rocket science
    http://www.pulstar.com/
  • TNTsTunes
    TNTsTunes Posts: 751
    A lean condition most likely caused the problem.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • concealer404
    concealer404 Posts: 7,440
    I just use the cheapest copper plugs i can find.
    Well, in the MX6 i use NGK V-Powers, but even those, i'm lucky to have them last 5,000 miles, but that's a whole 'nother story altogether.
    The thing that pisses me off about the Pulstars is that every car magazine has their stupid ad where they show a dyno of like a 7hp gain on a G35 using these things. And they're expensive as hell.
  • thsmith
    TNTsTunes wrote: »
    Yreah, the plug burns hotter. Jury is still out if the right heat range was used but I am betting it was.
    YMMV
  • concealer404
    thsmith wrote: »
    YMMV
    Ehhh... detonation and lean aren't necessarily the same things. Hotter plugs may cause detonation, but not necessarily a lean condition, because the plugs really don't have a big impact on a/f ratios.
    I think what we're seeing here is detonation, not necessarily leaning out causing the crack.
  • mmadden28
    mmadden28 Posts: 4,283
    I use Cardas spark plugs :)
    ____________________
    Pool: Atrium 60's/45's
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    From our 96 Honda to our newest Honda's we do not use the factory recommended plugs. Instead we use Bosch iridium's never had a problem.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • concealer404
    Surprising.... :p Hondas and Toyotas tend to hate Bosch plugs. My Toyota will misfire on brand new Bosch plugs, no matter the gap.
    Consider yourself lucky. :)
  • Face
    Face Posts: 14,340
    I'm also a fan of No Good Kind.
    Tracy, I'm having a hard time believing that the plugs are at fault. I would lean more towards a faulty injector or knock sensor.
  • Serendipity
    Serendipity Posts: 6,975
    Face wrote: »
    I use NGK too.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • concealer404
    Lasareath wrote: »
    I always put in the best sparks I can buy and the best wires. Just like how I try to use the best wires in my stereo system :D
    Do you notice a difference? What makes them the best? ;)
  • gdb
    gdb Posts: 6,012
    I always use Champion spark plugs on my fishing boat.
    I use em for sinkers !!:D
  • concealer404
    gdb wrote: »
    Don't laugh, but that's what i run in the Celica i race with. :eek: The 90-91s came with Champion coppers as OE, and i use them in my 92 with great results. They might not last QUITE as long as the NGK coppers, but at 79 cents apiece, who cares? I replace them every season at least once anyways. :D
  • thsmith
    Face wrote: »
    I guess it could be but I would have thought a knock sensor would cause a check engine light.
    In any case the motor was smooth and ran normal temps up to the point when all of the sudden the miss started to happen.
  • sucks2beme
    sucks2beme Posts: 5,686
    There seem to be some odd problems with these plugs. A combination of poor quality control, and some computer glitches caused by the different design.
    Either way, something went horribly wrong to whack the pistons.
    It could have nothing to do with them, either. That's the problem with
    sudden failures with no warnings or codes.
  • virtualdean
    virtualdean Posts: 286
    thsmith wrote: »
    I feel for you...Ford truck motors are bulletproof. That snake-oil plug sounds like they are way too hot. What will it cost you to replace the motor?
    Can you load the huckster plugs into a blackpowder musket and shoot the old mechnanics car?:biggrin:
