I Need Help !!!!
Systems
Systems Posts: 14,873
edited May 2003 in Car Audio & Electronics
Hey guys i was wondering whatamp you would pick outa the 2imabout toname to drive 2 Polk Audio GXR 124's. The amps are Power Acoustic 820watts, and a Pioneer 800watt max. Ok the specs. for the power acoustic are 180watts rms @4ohms x2. The Pioneer amp puts out 150watts x2 @4ohms. The power Acoustic amp is $124.00. The Pioneer is $119.00. And do you guys have any idea what brandof wires to use to hook up an amp. If anyone can help me out that would be great, you can find the power acoustic amp at www.justamps.com. And you can find the pioneer at www.carmedia1.com.
thanks
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited May 2003
    poweracoustik is a pile of ****.
    the pioneer is the way to go.
    but dont get GNX 124's.. get GNX 128's or dual 4's -- i dont know the model number.. but they make a single 8 or a dual 4... either of which would allow you to run that amp bridged mono and thus get 200 to EACH sub instead of 150.
    as i said in the other post - that's the best bang for the buck.
    The Artist formerly known as PoweredByDodge
