Help with setting receiver low pass filters
edited February 2010 in Speakers
Hello all,
I have question about the low pass filters in my receiver. As of the audyssey setup it set all of my speakers to large with the associated low pass filters set to 40 hz. The LFE + Main low pass filter setting is at 80hz. Does this seem reasonable for my setup? What do you guys recommend for the low pass filters?
Thank you,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Post edited by chiptouz on
    My Denon 790 did the same. I've messed around so much with various settings that I'm almost burned out playing with it. However, I've settled on the following (for a few days...):
    Fronts Large
    Center Small 60HZ
    Surrounds Small 80HZ
    Sub LFE + Main
    LFE 120HZ
    I seem to get the best integration of bass for music if I leave the fronts as fullband. The sub still kicks in and operates in two channel with this setting. It is pretty seamless on bass runs yet still really punches for home theater.
    My recommendation is play around and set it to suit your tastes and system capabilities. You're the only judge whose opinion is important.
    Polk RTi8
    Polk Monitor 40
    Polk CSi5
    Polk MicroPro 2000
    Visio 42 LCD
    Denon AVR 790
    Samsung BD 1600
    Two Channel
    Polk SDA 2B
Welcome!
Welcome!
