The benifits of running a Balanced system.
dc55110
It is time to finally upgrade the weakest link in my set-up, my preamp. In this case it's an old Denon AVR in bypass mode(direct mode these days) . Both my DAC (Theta DS Pro Basic IIIa) and my amp (White Audio Labs B1) are balanced designs (as far as I know, as I'm not the original owner and cannot find much info on the designs of either components). My current budget is about $600 for a new pre, but after looking around for a while most pre's in that price range that have balance in/out-puts are not truly balanced, balanced in/out-put connected to a single ended line.
Would it behoove me to save a while longer and maybe double my price range? Ideas? Suggestions? Or should I not even worry about going with a balanced system and focus my attention elsewhere?
(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
Transparent SoundWave Super
Paradigm Studio Monitor
B&W 802 s3
HT
Sony Bravia KDL-40Z4100
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
Post edited by dc55110 on
I think it really depends on the gear. A bad circuit with balanced ins and outs will not sound as good as a good one with rca's.
Just go for whatever pre sounds best to you (balanced or unbalanced). Or are your other equipments balanced only with no rca's? -
You can try the Marsh balanced preamp; you can find them within your budget used._________________________________________________
Balanced is generally recommended for long runs. And don't forget that balanced connections usually add about 3db of gain which must be taken into consideration when doing comparison listening. At a 3db gain you will always preceive that to sound better. Level matching is key to get a fair comparison.
I think that the Adcom 750 pre-amp would work for you. I also have the
Theta Pro Basic iiia dac..........sweet:)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Something like this,,,,,,,,
http://www.audiogon.com/cgi-bin/cls.pl?preatran&1271863287&/Adcom-GFP-750-Pre-AmpLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Why not enter the world of a tube pre amp?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Anyone have any experience with either the Classe CP-60/65?(((STEREO)))
Sony DVP-N9000es
Squeezebox Duet
Theta ProBasic IIIA
Audio Research SP14
White Audio Labs B1
B&W 802 s3
HT
Sony BDP-S350
Yamaha HTR-5790
NHT SB3 (Fronts)
NHT SC2 (center)
NHT SB2 (surround)
Velodyne FSR12
