Need rear surround advice....
dl090465
Hello all,
If you look at my sig, in Room 2, I am using FXi30's as my rear surround speakers. I have a pair of RT1000P's that I was going to sell, but am thinking about making those the rear surrounds in Room 2.
At the moment I have that extra set of RT1000p's and another spare set of FX30i's...this would leave me with two pair of extra FXi30's but will put back the RT1000p's in use.....is this a good idea??
I wont touch Room 1.......it is just too perfect !!!!!!
Thanks !!!!
Thanks !!!!
Room 1:
ONKYO TX-SR608
Polk Complete RT 5000 System
Polk RT3000p's Front
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
Post edited by dl090465 on
If you have the room and it is aesthetically pleasing, it sounds like a good idea to replace your FXi30's with the RT1000's. I don't see where you have a subwoofer listed for either room so that makes a difference in a recommendation. The RT1000's will add some additional bass to the rear but might not be as noticeable if you have a decent sub. Since you have both the 2000's and 1000's, you know how much better the 2000's are in the bass dept.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
On second thought, if you don't have a dedicated sub, sell the 1000's to fund the purchase of a sub.____________________________________________________________
i just updated my sig, I have subs in both rooms...the one in room 2 an an 11.5 year old 10" Infinity and it hits fairly hard...Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
Cool. Try it and see if you like it. Pick the option that sounds the best to you.____________________________________________________________
WOW...I am glad I tried this....My room with the RT2000's and FX1000's use to sound better, but replacing the FXi30"s and using my spare RT1000P's as surrounds is killer !!!!Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
I now have two pairs of FXi30's lying around...I guess I should take some pics and see what happens in the for sale forum....Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
