4 12 1 1000 Watt Crossfire Mono Class D Amp
Systems
TRYING TO RUN 4 12 AND NEED TO KNOW IF I CAN RUN THEM ON MY AMP AND WHAT KIND OF WIRING CONFIGURATION IS CALLED FOR THIS SITUATION
Testing
Testing
Testing
Testing
Testing
the crossfire does its power at 2 ohms right?
if this is so then you'll need four dual 4 ohm coil / single 8 ohm coil subs... of which you'd be using something like the Polk GNX.
if it does its power at 1 ohm, then you can use 4 single 4 ohm coil momo 12's, however i doubt that amp is nearly enough power for 4 momo's.... 2 yes... 4 no.The Artist formerly known as PoweredByDodge
