PSw10
Mike Kozak
Mike Kozak Posts: 931
edited February 2010 in Electronics
ok I am not getting any sound out of my PSw10 Sub, it seemed to work yesterday. I ran the Audyssey setup today, keeping the volume on the sub low. the power light is on the back of the sub, Any ideas on how I can test this? I am going to take it to my neighbors tomorrow to test it on his system, but if I can get it fixed tonight that would be great.
Post edited by Mike Kozak on
  • Mike Kozak
    It is fine now, I had the cables squished against the wall, once I moved to whole setup out from the wall, the sun is now working
  • Mike Kozak
    On second thought I have found out something since hooking up my new Monitor 70s. Now the sub will only kick in when the volume is turned up, then is fine after that, both low and high volume. Why would my sub have to be "woken up" at first after I power on the system? The setting on the sub is as follows....Auto
  • adabro
    adabro Posts: 212
    Mike Kozak wrote: »
    The Auto setting will turn it on when it senses a signal - did you have it set to "On" before?
  • Mike Kozak
    No it has always been set to Auto. Now it seems to be working Ok, intermittent problem I guess.
