polk rtia7 or lsi9
looking to buy 2 fronts polk speaker for front room side 40x16 sould i get the rtia7 or lsi9 which would work best side room if anyone can help thanks
Post edited by rmoody on
Welcome to CP.
it would depend on the primary use in my opinion. If it is for mainly music many would recommend the LSi's. If it is a HT application the I would vote for the A7's. What amp/recevier will you be using to power these. The LSI's are a little harder to drive and may end up needing more power. Either would be a good choice though. Do you plan on using a sub as well?Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Seems to me you're talking apples and oranges here. Big room ... big speakers.Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2 -
thanks i have h/k 354 & yes i have 2 velodyne 3750s paradigm adp 190 cc & paradigm adp190 rears
50-50 h/t & music
Welcome to the Club!
RTiA9s would work great in that large room that you have.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Agreed - Get the A9's unless you want to fork out some serious cash.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
With the RTiA9's, like the RTi12's, you'll need to tame the tweeter a bit for music.
Very easily done.
Rti a9's get my vote because you're looking for a 50/50 system. 2 channel I'd go SDA's. They can be had cheaper than the LSI9's and they sound much better. They also function very well for a dual purpose system. -
And you tame a "tweeter" how?Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
With a good amp, I prefer the LSi25's, or LSi15's or LSi9's over the RTi12's.
HT or music? -
LSi9's...without question. They are better in every single way IMHO.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Love my LSi9's, but without a sub they lack low end bass. I need my sub for music too. For HT you will use a sub anyways. For music, some people don't like to run a sub. My HSU sub gives me some seamless base so it's a non-issue.
I have owned only the RTi6's and can only compare to them. They were too bright for me. Although I mainly listen to music, I love the LSi's (have an LSiC) for HT better than my RTi6/CSi5. For me the soundstage seems more seamless, and the vocals are far better. Your mileage may vary.
