Speaker wire length question
Mauskar
Mauskar Posts: 104
I've decided to add Rti4's as surrounds to my RTi10 fronts powered off an HK354. I wanted to know if the length of speaker wire have to be the SAME for ALL speakers???
Running, 16 AWG roughly 12-15ft...
thanks
  • dorokusai
    dorokusai Posts: 25,661
    edited February 2010
    I wouldn't worry about it unless your talking a couple hundred feet of difference.
  • cstmar01
    cstmar01 Posts: 4,424
    no they do not, however if you are getting them custom done from a company such as signal cable or others resale value can be hindered as a lot of people would want a pair of 8ft and not one 8ft and one 15ft. otherwise go for it.
  • dorokusai
    That's a good point. I usually keep mine of equal length.
  • jacob.simpson
    jacob.simpson Posts: 481
    Its better if its equal length,
    but for a shorter within 30 you can
    go with + /- 5'
