Ordering Caps/Resistors for SDA 1C's
Toolfan66
Toolfan66 Posts: 17,333
edited February 2010 in Vintage Speakers
OK just so I am on the right path here, Thanks in advance for the info.
I need:
2 40UF
2 20UF
2 12UF
2 4.4UF
4 7.5 5w Resistors
2 2.7 5w Resistors
2 0.5 ohm Resistors to replace the poly's
Now I do see a little looking purple thing that looks like a poly as well/ What the hell is it? is it the 750pf that i can eliminate?
My plan is to use all Sonicap's (i would like to order tomorrow) can I order the mills from them as well? do they have them or do I need to order them from someplace else?
Thanks.
Larry.
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
Post edited by Toolfan66 on
  • hearingimpared
    hearingimpared Posts: 21,136
    I need:
    2 40UF
    2 20UF
    2 12UF
    2 4.4UF
    4 7.5 5w Resistors
    2 2.7 5w Resistors
    Thanks.
    Larry.
    I believe that is a silver mica cap. Ask Jesse about it for more info. . . he's up right now.
    heiney9 Posts: 25,217
    It's a bypass cap. Delete it now that you are using premium caps.
    Dude there are atleast two dozen threads on upgrading 1C's all the info you need is there. :) You can order Sonic Caps and Mills from Sonicraft.
  • ben62670
    ben62670 Posts: 15,969
    Also take a peek at Clarity caps. Hp and face have used them. If you want them from madisound use the mox resistors.
    Ben
    Ben
  • thsmith
    thsmith Posts: 6,082
    Larry, this is my link when I did mine. Hope it helps.
    I used a solder wick for removing the old parts, I prefer it over suck bulbs but YMMV. Also order the cardas solder from sonicraft. I also asked for matched cpas as well.
    If you would like to review over the phone send me a PM with your number.
    It is easy just take pictures, do one side at a time and be patient.
    http://www.polkaudio.com/forums/showthread.php?t=89067&highlight=journey
    Sonicaps and Mills are ordered, and the RDO-194's ordered yesterday. I will be disassembling these babys this weekend so I can get the wood caps to the paint shop next week.
    I need to order some brass for the spikes, dynamat and grill cloth. I still have mortite.
    SVS SB16 X2
  • hearingimpared
    Dynamat Extreme Bro.
    But of course my good man....;)
    SVS SB16 X2
  • Paden501
    Paden501 Posts: 286
    Yeah the Dynamat helped a lot.
    You can't go wrong with the Sonicaps, but as Ben said, a lot of us have had success with the Clarity Caps as well.
    Good luck.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
