Hot rodding my SDA 2.3s Questions
hogsfly
Ok been living with my 2.3s for a little while now.Have done some dyi like polyswitchs gone,drivers and PR's damping ,Improved IC. Now my problem do I go for the TL upgrade or just or do caps and go with new RDO's? Also I'm currently driving them with a older Technics amp SU-85A with 120 a channel dont listen at high levels just moderate levels;) Any amp advice and what about biamping? I listen to a wide range of muisic.I'm very pleased with the SDA's now.Thanks for any advice that u feel is important!!!!
2 Channel System
POLk AUDIO SDA SRS 2.3
Proton D1200 amp
Proton P1100 preamp
Proton T440 tuner
Sony CDP-291
Sony CDP-591
Proton D1200 amp
Proton P1100 preamp
Proton T440 tuner
Sony CDP-291
Sony CDP-591
Post edited by hogsfly on
Do everything
If you use the search function on this forum and do a lot of reading it will benefit you greatly.
Upgrading will cost a few bucks and will be well worth it to say the least. RDO's are a simple/easy upgrade and at $50.00 each a wise move.
After they burn-in and you get the benefit of the better tweeters I'd move on to the x-overs. This is when you need to study a little and ask questions. Its not that difficult if you prepare and take your time. You could always send them (x-overs) to our resident doctor (Ben) for the upgrade.
Mye sound spikes are a easy upgrade and a good one too! https://myesound.com/Home_Page.html
Good luck -
I have the spikes that came with them and they are in use.Sounds like I need to do some more reading around here!!!!!!!!! You guys are awsome I think thats part of what makes the older polks the best even if they are 20 something!!!!!!!!!!!!!!!!!!!!!2 Channel System
Proton D1200 amp
Proton P1100 preamp
Proton T440 tuner
Sony CDP-291
Sony CDP-591 -
I think trying to turn them into tl's might be quite an undertaking,, when I had my 2.3's,, I upgraded the crossovers with sonicaps amd mills resistors,popped in the rdo 194's,,and i could have lived with those for years,,alas,, too much speaker for my room size..nothing wrong with a pair of upgraded 2,3's,,good luck,and enjoy.JC approves....he told me so. (F-1 nut)
hogsfly, modifying 2.3's to 2.3TL (2.3SD really; SD=Silk Dome) is fairly costly, compared to upgrading the crossover and tweeters on an existing pair of 2.3TL's. All the inductors except one are different, all the R's except one are different, all the C's except 1 are different, and the crossover topology is slightly different so you have to change/add the different connections. 4 of the midbass drivers are different (or maybe it's 2; I forget), and I think there's also some cabinet structural differences.
There've been a couple threads about this. I'll see if I can find them later.
Bottom line, it can be done, but it's more work and more costly than a resto-mod of an existing pair of 2.3TL's.
edit: here's a link to one of the threads (and additional links within this thread)
http://www.polkaudio.com/forums/showthread.php?t=84257 -
I'd do the xovers and stick with the RD-0194.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
ditto that. I did exactly what Mark is suggesting. I did use the Mortite around the woofers and tweeters and put on some nice spikes. The modest, inexpensive changes tightened the base and seemed to focus the image. Don't forget to upgrade your interconnect cable. You can also get some better cable terminals and jumpers. Some folks will wire the terminals together to eliminate the need for a jumper. This is a very cheap mod if you don't intend to biwire or bi-amp. Plus if you use ring terminals the mod is completely reversible.
Good luck! The SRS-SDA 2.3's are awesome sounding speakers!Carl -
+1 to what Doro said. Someone will correct me if I am wrong here, but I believe there to be a few differences in the internal cabinet bracing as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Not to mention that the right speaker would have to become the left speaker and vice versa.
If you really want 2.3TL's, buy a pair.Political Correctness'.........defined
President of Club Polk -
Interesting...I did not know that part of the story.
So a regular 2.3 is oriented like this? (just guessing) :
left speaker
S
DTs
DTs
ST
right speaker
S
sTD
sTD
TS
where T is for tweeter, D is for dimensional driver, and S and s are the stereo drivers (and I'm just guessing, they are set to have slightly different response) -
Yeah, basically except the top and bottom outside edge drivers are sub-bass (SB) drivers.
left speaker
SB
D T S
D T S
SB T
right speaker
......SB
S T D
S T D
...T.SB
Damn thing won't let me post the letters where I want, but you get the idea. Let's try adding some dots.Political Correctness'.........defined
Well First of all THANKS to everyone for some good info!I have descided to do the Xovers first and then RDO's after caps burn in well be moriting drivers after its all done. Have it already just did use it cuz I knew I'd be opening them up again.Felt kinda bad opening them up bein the orginal owner hadn't but after upgrade we will seal them up and not look back!!!!!!!!!Will let you all know when its done .THANK YOU ALL2 Channel System
Proton D1200 amp
Proton P1100 preamp
Proton T440 tuner
Sony CDP-291
Sony CDP-591
