Monoprice Speaker Wire
MillerLiteScott
MillerLiteScott Posts: 2,564
edited February 2010 in The Clubhouse
Does anyone have any experience with the 12 guage speaker wire in the clear jacket from Monoprice.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2789&seq=1&format=1#largeimage
I will be using it for a fundraiser I am doing at the end of the month and for utility speaker wire after that.
TIA
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • Amherst
    Amherst Posts: 695
    Hi Scott! Been using that cable for years. I don't really know crap about cables but have my LSi's on it now and sounds fine.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • Demiurge
    Demiurge Posts: 10,874
    Monoprice sells quality stuff. I just got a bunch of cables delivered yesterday, including 250 ft of speaker wire and its good stuff.
  • TNRabbit
    TNRabbit Posts: 2,168
    I bought a 100' reel of it 2 years ago; it's a great, bargain-priced wire.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Huck344
    Huck344 Posts: 453
    I have the 12 gauge. It works ok I suppose and should be fine for your application. The one issue I do have with the wire, is that +/- are not marked very well, or rather, there aren't any real clear markings on either wire.
  • Knucklehead
    Knucklehead Posts: 3,602
    I use MP 14ga, works for me.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Amherst
    Amherst Posts: 695
    One side of the insulation around the conductors should have a ridge on the outside edge. I can't see it very well with my eyes, but is fairly easy to feel with your fingers. I believe the conductor with ridge should be designated as the negative side of the pair.
  • packetjones
    packetjones Posts: 1,059
    i use monoprice wire as well. Never had issues with it. I would say that stripping the wire could be easier than it is but overall it is good bargain wire.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • zingo
    zingo Posts: 11,258
    I have their white jacketed CL3 rated 12g wire and it's great.
  • ViperZ
    ViperZ Posts: 2,046
    I have that wire. Very nice, flexible wire. My B&Ws sound great, and I am sure they'll sound great with the same wire when I'll hook up the Rotel amp. :D
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • unc2701
    unc2701 Posts: 3,587
    zingo wrote: »
    I have a huge box of that for all my in-wall stuff and I totally agree. Pulls very well, too- no snags and the jacket is slippery enough that you can get it to slide around a few corners before the friction gets to be an issue.
    Backburner:Krell KAV-300i
  • potee
    potee Posts: 610
    I their 14 ga in the white jacket and never had a problem. By the way in the jacket the wires are solid red and black cn't make an error.
  • ramm440
    ramm440 Posts: 92
    Which one is the better wire or not much difference?
    F1nut Posts: 52,154
    Both are crap.
  • Emlyn
    Emlyn Posts: 4,868
    Look the same to me as generic 12 AWG copper stranded cables except for one being on a sale price. Maybe they're clearing out an older version. Could get 200 feet for the price of 100 feet. Still crap though.
    :D
    txcoastal1 Posts: 13,519
    The dialectic properties of that clear coat is not good and will turn the copper (if that's what it is) green, sooner than later.
  • mrloren
    mrloren Posts: 2,474
    I had that clear coat Monoprice stuff in the bedroom HT. turned green in a couple years. The in-wall I have going to the surrounds is still good over 15 years.
    The Monoprice and Amazon basic are not bad entry wire. If you're serious about audio then just look for some Canare 4S11 and be done with it
  • DaveHo
    DaveHo Posts: 3,583
    Take a look at the furez fz10/as. Better than the canare. Douglass connection sells it. @helipilotdoug
  • mrloren
    Yes Furez is a good choice too.
    Once going above the entry stuff $$$ is the limit. I like to stay within $1-2 a foot.
    F1nut Posts: 52,154
    No one buys an amplifier by the price per watt, so why people buy speaker cable by the price per foot boggles the mind.
    VR3 Posts: 29,627
    To be fair there is quality wire out there sold by the foot??
    Supra quadrax and rondo, duelund dca, etc etc... Plenty of options
    F1nut Posts: 52,154
    Sure some speaker cable is sold by the foot for the DIY types, but the price should be judged by the total length required.
    Let's say I need 8 foot runs, so the cost total is for 16 feet. Breaking it down to the cost per foot is silly.
  • jdjohn
    jdjohn Posts: 3,415
    DaveHo wrote: »
    Is Doug still in business? His website is up and active, but when you try to drill down to actual products, the web pages are all dead.
    For example: https://douglasconnection.com/products/diy-and-save-do-it-yourself/raw-cable-for-diy/raw-speaker-cable/
    pitdogg2 Posts: 27,558
    Doug has been MIA in a lot of places, I had asked months ago if anyone had spoke to him recently and got nothing but crickets.
  • mrloren
    I DIY all my speaker cables that is why I price it by the foot. If I was buying a 8' cable I would look at the cost of the complete cable and not break it down the cost per foot.
    F1nut Posts: 52,154
    jdjohn wrote: »
    DaveHo wrote: »
    I was just on his site and everything seems to be working correctly, even your link works.
    http://douglasconnection.com
    It wasn't at all when he posted that. A few months or so earlier I had the same issues when trying to access his site.
    Glad it's now back to working.
