PSW10 Connection to ROTEL Amp help....
HiFiNewbie
Hi, I am wondering if someone could help me figure out if the connections I have to my new sub (PSW10) are in fact correct. I have a smalle set up of bookshelf speakers, a record player, and a cd player. I am running a ROTEL Integrated Amp (RA-840BX2) which is driving 2X Heybrook HB-150s. I have added the new sub (PSW10) for some low end sound but am unsure of the connection, which is not shown in the sub literature. What I have connected now is from the ROTEL Amp speaker outputs (left/right) (using 12 gauge speaker wire) to the sub speaker inputs (left/right) It seems to be working and also seems like my only option considering the use of the integrated and not a reciever. Does anyone know if this is correct/ok? What are my options if this is not the prefferred method? Do I need a pre-amp?
Could someone help me with this....thankyou
Thanks for your time
Braeman
Braeman
Post edited by HiFiNewbie on
It looks as though that is your only option unless you want to use your headphone jack as a preamp out.
Connect your speakers to the direct out terminals. Buy a 1/4 inch stereo plug to stereo female RCA adapter. Plug the adapter into your headphone jack then use a stereo subwoofer interconnect between that and the RCA inputs on the sub. I did this back in the '80s. Works great as long as you don't need to use your headphones. I was able to fold the adapter under the chassis to hide the wire so it wouldn't look too obtrusive.
Not the best work around but a work around none-the-less.
Welcome to Club Polk!
Den
Parasound 2100
Parasound 2125
Denon DCM-390
LG BD390V
Martin Logan Preface(x2)
Denon AH-D2000
Bedroom
Adcom GTP-350
Parasound HCA-800II
Panasonic DVD-S54
Denon AH-2000
Polk S4(x4)
ಠ_ಠ
