Help With Rear Speakers
Rcross
Rcross Posts: 2
edited February 2010 in Speakers
I'm Actually considering upgrading my rear speakers either to OWM 3 or OWM 5, Which could go better with my current set-up, which is:
tsi100 for Front
Cs10 for Center
Psw10
Sony Str-Dh800
The room size is around 13 X 13.
Post edited by Rcross on
  • cwilliams
    cwilliams Posts: 58
    Either one. The OWM5 has more bass (dual drivers), but is also twice the size. Are you wall mounting?
    Chris
    5.1
    Denon 890
    Polk TSi300
    Polk TSi100
    Polk CS10
    MTX SW2 Sub
    2.0
    Polk SDA-2A
    NAD 7175PE
  • lmacmil
    lmacmil Posts: 119
    Rcross wrote: »
    tsi100 for Front
    Cs10 for Center
    Psw10
    Sony Str-Dh800
    Have you considered M10s? I got a pair from Polk Direct (Ebay) for $74 shipped. They sometimes go for less. I suspect they would be better sounding than either of the OWM models (if the specs are any indication).
  • packetjones
    packetjones Posts: 1,059
    the OWM3's are pretty nice. The mounting options are great. I had a pair of them before i moved my A3's to the rear. i would go with the 3's over the 5's based on the front speakers that you have. In fact i would look at upgrading my fronts and moving the 100's to the rear. There are/were some grewat deals on polk direct.
    Ohh and welcome to the club.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • Rcross
    Rcross Posts: 2
    Yeah, they would go wall mounted, i'll try and searching on ebay, thanks for the advice.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Another set of TSi 100's would also work well for your surrounds. Although the OWM's do have more/better mounting options. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
