HDMI splitter
wrigley
wrigley Posts: 79
edited February 2010 in Electronics
My daughter has an older 1080p LCD TV with 1 "HDMI in" and 1 "HDMI out". She recently upgraded to HD cable and she also has a Sharp BD-HP22U BD player. Can she use a basic HDMI splitter or does she need to go to an amplified splitter switch?
The cable company (Comcast) told her to use RC cables for the HD connections. I'm not an expert, but I think she will get a better picture using the HDMI connection? Thanks
Mike
Post edited by wrigley on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Yeah, HDMI is the best, but if the units support Component cables, they are probably second in line. Get an HDMI switch box and you will be good. They can be a bit pricey though, the cheapest one I found was $55, but I'm sure they can be had for less. If not, component cables would be cheaper, and the picture quality wouldn't suffer that much, IMHO.
    -Jeff
    http://www.buy.com/retail/product.asp?sku=211118621&listingid=43066813 splitter box
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Slinger182
    Slinger182 Posts: 512
    I don't have any experience with a splitter but my buddy has this switch and hasn't had any problems.
    http://bluejeanscable.com/store/hdmi-accessories/index.htm
    Panny 55-st30 plasma
    Pioneer vsx-1121
    Parasound 2100 pre
    b&k tx4430 amp
    Oppo bdp-83
    Monster HTS 3500
    polk TSi500s Vr3 Fortress modded
    polk CS20 center channel Vr3 Castle modded
    polk Owm 3 surrounds
    polk PSW505
  • unc2701
    unc2701 Posts: 3,587
    OK, she need a switch, not a splitter. Splitter would drive 2 TV's off one source; switch allows 2 sources to go to one input. Monoprice has plenty of cheap models:
    http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10110
    Backburner:Krell KAV-300i
  • wutadumsn23
    unc2701 wrote: »
    That was what I linked in my post, no? Figured they could be had for cheaper, just wanted to let him know what he was looking for.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • unc2701
    -Jeff
    Response was to the OP. Your post wasn't up when I started my response.
  • wutadumsn23
    My bad.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • wrigley
    wrigley Posts: 79
    unc2701 wrote: »
    Thanks guys....I appreciate the info. Does she have to worry about HDMI 1.1, 1.2, 1.3, etc.....when selecting a switch box?
    http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011001&p_id=2786&seq=1&format=2
    Mike
  • cheddar
    cheddar Posts: 2,390
    I have used the monoprice 2x1 manual switch with good results. HDMI is notoriously difficult to get a proper handshake with. The manual switch physically moves the connection from one source to the other. You can hear the new connection clicking in to place when you push the buttons. So you aren't messing with the signal, just creating a new physical path.
    Although I haven't used others, many switches electronically switch the signal and create another point where handshake failure can occur. So although they have ratings, they may be less reliable than the manual switch.
  • cstmar01
    cstmar01 Posts: 4,424
    Also check to see if the comcast box is really putting on 1080P. Most are still putting out 1080i which can be passed through component cables just fine, as well as you normally will not be able to tell a difference between 1080P and 1080i on TV's that are a bit smaller, normally around 42-46" and below. If you can hook up via component then all you would need would be the 3 cables and a opitical cable or digital coaxial cable for the sound. HDMI does make it a bit easier for you to just use 1 cable, but as noted there can be handshake issues when using them but normally a switch isn't too bad to work with.
  • Huck344
    Huck344 Posts: 453
    I have the below monoprice HDMI switch. I've used it for about a year. I have my PS3, BDP, Directv box and Xbox360 connected to it. I've never had a problem. I like that it has a remote function.
    http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=4088&seq=1&format=2
  • wrigley
    wrigley Posts: 79
    cstmar01 wrote: »
    Yeah.............it's probably 1080i. I have DirecTV HD and it's 1080i.
    Mike
  • wutadumsn23
    wrigley wrote: »
    Mike
    Same here, and I have Comcast. HD channels are broadcast in 1080i for me.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • ViperZ
    ViperZ Posts: 2,046
    It's like $10-15 difference to get a full blown 4-to-1 1.3b-certified remote-operated switch. I think it's worth the extra money, considering that it can be used with newer equipment.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • grif32
    grif32 Posts: 267
    cstmar01 wrote: »
    There is nothing that broadcast in 1080P and probably won't for a very long time. So 720P/1080I is all you will ever get. So all should still be putting out 1080I and not 1080P
    To the op:
    I have a Monoprice 2x1 switch part #HDS-201 you can have it, if you pay shipping. Its a manual switch. Or you can just use component and rca cables/optical etc for sound for the cable box and HDMI for the Blu-Ray player.
    LMK
    Chris
    (3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
    (2) Panny DMPBDT110 3D Standalone Players
    Panny 60" 3D Plasma TC-60ST30
    Panny 50" Plasma TC-P50G10
    Panny 50" 3D TV TC-P50GT25
    Denon AVR-891
    Harmoney One Remote
    Polk Monitor 70's,Polk CS2, Polk Monitor 40's
  • wrigley
    wrigley Posts: 79
    grif32 wrote: »
    To the op:
    LMK
    Chris
    Chris,
    I appreciate the offer. She decided to just use the RCA cables for now. Thanks again for the offer! :)
    Mike
  • grif32
    grif32 Posts: 267
    wrigley wrote: »
    Chris,
    Mike
    NP Mike...
    Denon AVR-891
    Harmoney One Remote
