Lsi15 Receiver and Amp Help!
  • jimmydep
    jimmydep Posts: 1,305
    edited February 2010
    RUSigX, The Sunfire Cinema Grand is a good match for the Lsi's. I bought mine used for about $750.00 off of e-bay, and it works great.
    The Sunfire has 200wpc@8ohms and 400wpc@4ohms, plenty of nice clean power for those LSI's.
  • RUSigX
    RUSigX Posts: 18
    Thanks jimmy! What are you using as a pre amp? I just made a guy an offer on a Sunfire Cinema Grand 200x7 for $1,100. Sounds like you got a good deal on yours for $750!
  • jimmydep
    RUSigX wrote: »
    Rus, that sound like a reasonable price, my Sunfire is the Cinema Grand 5.
    Right now I'm using a Yamaha RX-v665 as a pre-pro, I think it does a very good job for HT, but I'd like to get an Anthem 2L for listening to music.
    I'm also using an Emotiva XPA-5 that I constantly swap out with the Sunfire, I like both the amps but I think the Emo has a slight edge over the Sunfire.
    Jimmy
  • Bernal
    Bernal Posts: 991
    edited March 2010
    RUSigX wrote: »
    I have been looking at some of the Sunfire amps (5 channel 200 and 400wpc models) and some look older than others. How long did they make the Sunfire Cinema Grand (Signature) models? I think I saw a review on one all the way back to 1996 or something. Not sure I would feel comfortable buying an amp that old!
    http://www.sunfire.com/productdetail.asp?id=3
