SDA Polyswitch bypass 5or12watt resistors?
wingzam
wingzam Posts: 201
edited February 2010 in Speakers
Just called Sonic Craft to order .5 ohm Mills resistors to bypass the polyswitches on these SDA-1B's,and the parts guy asked wether I wanted the 5 or 12 watt resistor..."um,uh,duh"...
What is the prefered value here?
Post edited by wingzam on
  • kcoc321
    kcoc321 Posts: 1,788
  • george daniel
    george daniel Posts: 12,096
    I've always used the 12 watters.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    12 watt
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • wingzam
    wingzam Posts: 201
    So unanimous.Unless there's a conspiracy going on here - c'mon,you wouldn't do that to me would you??
  • ben62670
    ben62670 Posts: 15,969
    12 watt in that position for sure.
    Ben
    F1nut Posts: 51,771
    The 5 watt will work with absolutely no problem. All of the original resistors used by Polk are rated at 5 watts. That said, there is nothing wrong with using the 12 watt resistors and most of us do.
    Of note, Mills states that their 5 watt resistors have less inductance than their 12 watt versions.
  • wingzam
    wingzam Posts: 201
    "Of note, Mills states that their 5 watt resistors have less inductance than their 12 watt versions"
    Wha??..i'll just go with the 12 watt.This little fix is just to keep the 1B's on the road for now while I recover from the Adcom 5800 purchase.Still have to finish the Kenwd M2 upgrade and want to hear it hooked up again for comparison of what it sounded like before the polyswitch removal and against the GFA.
    Then it's a recap for the 1B's
    So glad I finally discovered this weak link (polyswitch) in the system - it's made huge difference!
    F1nut Posts: 51,771
    Wha??..
    The MRA-5 (5 watt power rating) exhibits even lower inductance than the MRA-12 due to its very compact size. It will handle overloads 5X its power rating (25 watts) for 5 seconds with operating voltages up to 500 VAC.
  • wingzam
    wingzam Posts: 201
    Why is the MRA-12 prefered over the 5 then?
    F1nut Posts: 51,771
    Because it will handle 10 times its power rating making it less prone to overheating.
    Bottom line, either will work perfectly.
  • wingzam
    wingzam Posts: 201
