What Center to Use with SDA 2a'?
fafner
As I have gotten more used to my HT setup with SDA2a's as fronts and surronds and M10's as rears, I am noticeing that my Yamaha center has a clear tonal difference than the Polks. The sound from the Yamaha is good and high quality just different from the Polks. I have tried using the setup without a center speaker and that simply does not work for HT for me.
Has anyone here found a center that fits very well with SDA's for this application?
Thanks in advance for help.
fafner
fafner
Fronts - Polk SDA2B's
Center - Polk 350CS
Surrounds #A - Another pair of SDA2B's
Surrounds #B - Another pair of SDA2B's
Rears - Yet another pair of SDA2B's
Subwoofers - 2 M&K's
AVR - Denon 3808CI
Display - Sony 52KDL4100
Blu-ray Player - JVC BP-1
HTPC - Self built - Intel Quad Core I7 920@4.0ghz
Center - Polk 350CS
AVR - Denon 3808CI
Post edited by fafner on
I liked a pair of CRS's with all the drivers powered best. Next was a pair of M5's. I also had a CS350 that sounded good."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
CS400i. You will have to find one on the used market."The secret of happiness is freedom. The secret of freedom is courage." Thucydides
I use a SDA CRS modded which works really nice as a matching sound. there may be better out there but if you find one for cheap its well worth it.
I use a pair of the CS400i in my system and I am very happy with them. Ideally you would use the same speaker for the center as the front pair which would also be the same as the rears - oh well to have unlimited funds, space and a very understanding wife although I really can't complain.
Good luck, Phil
SRS-SDA Front
2 cs400i Center
SRS-SDA Rear
Shure 12in sub
B&K ref 10 pre-pro upgr to ref 50
Techniques 1200 TT
Mac MR71 Tuna
Lexicon rt-20 uni player
HK citation pre for TT
2 PSE Studio Mono Blocks
4 PSE Studio Stereo Amps
1 Mac 2100 Amp for sub -
My CSi5 works well with my 2A's. It's not a perfect tonal match, but it's always been close enough for me.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I use a Aperion Intimus 6C from Aperion speakers in Portland, Oregon with my SDS SRS 2.3TL's.
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
