old Cerwin Vegas
ibewbrother
ibewbrother Posts: 186
edited January 2012 in Vintage Speakers
A friend of mine's dad has a set of Cerwin-Vega AT-15's. They are hooked up to an old Onkyo pre-amp power-amp set up, and he has hinted that he might be wanting to sell them. The speakers are HUGE.. 15 inch woofers and weigh about 70 pounds each. I was figuring offering about 200-300 dollars for the whole set. It's all about 20+ years old..but they still rock...any thoughts?
...Brother
"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807
Post edited by ibewbrother on
  • concealer404
    concealer404 Posts: 7,440
    edited February 2010
    They're loud.
  • George Grand
    George Grand Posts: 12,258
    How bad do you need firewood? Onk pre and power combo might be interesting, especially for only a couple hundred bucks.
  • ibewbrother
    This stuff dates back to the 80's. The onkyo power amp has twin analog power meters on the front and is as big as my new onkyo 806. It might be a tube model...I have listened to these several times and you 2-channel guys should note.....no sub needed....15 inch vegas boom. All of this probably dates from '85 or so....my friend had an onkyo integra set up and didn't like the pre/power of the one I'm interested in
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
  • Knucklehead
    Knucklehead Posts: 3,602
    Theyre not for critical listening....put em in your garage and throw a big **** party!:p:D
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • superjunior
    superjunior Posts: 1,632
    hey brother, I had a simmillar inquire about cerwin vega speakers recently and it wasn't met with mutch enthusiasum with our polk brothers. after doing a bit of research it seems cv has been around for a long time and is best noted for making a very efficient and easy to drive LOUD speaker, lots of base and just noisy otherwise. if your looking for a very base heavy speaker with no detail and painfull highs than hey. just my opinion of course, but I've dismissed cv in my quest...
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • concealer404
    The amp sounds like an M504 or bigger. Nice amp.
  • halo71
    halo71 Posts: 4,632
    yeah if its a M504 with an Integra pre (maybe?) those for sure would be worth a few hundred. I would forget the CV's though.
    --Gary--
  • gdb
    gdb Posts: 6,012
    I was going to buy some CVs off ebay to use as outdoor LOUDspeakers while I did an exterior remodel on my house. The seller backed out of the sale and I got some Polk Monitor 10As to use instead. I'd say buy them + Onkyo stuff, try them for a while, then sell the CVs and buy Polks.;)
  • George Grand
    You do not have tubes in that thing.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    CV's are worth their weight in firewood. Nothing more, nothing less.
    They're great at pumping out bass, and sounding like **** otherwise. They're great for college dorm parties...and that's about all I can give them.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • dbayyz
    dbayyz Posts: 2
    edited January 2012
    I have an Onkyo TX-SV727 Specs:
    FEATURES:
    DISCRETE OUTPUT STAGE: The TX-V940 employs an All Discrete Transistors in the output stage for effortless drive into low impedance loads
    POWER COMPONENTS: Dual 6,800 uF Capacitors, Over-Sized Isolated High Power Low-Impedance Transformer and Extruded Aluminum Heat-Sink, which effortlessly drives 4 ohm loads
    POWER OUTPUT: 100 Watts RMS x 2 @ 8 ohm/ 130 watts @ 4 ohms
    Frequency Response: 20 Hz ? 30,000 Hz
    THD: 0.08%
    Signal to noise ratio: Tape/CD 100 dB, Phono 80 dB
    Phono: MM output 120 mV
    Damping Factor: 60 at 8 ohms
    Video Dubbing capability
    Adjustments: Bass, Treble, Balance
    Selective Tone Control
    Six Class Classifed tuning
    Local/Dx auto/mono/Automatic Precision Reception (APR)
    FM Quartz Synthesized Tuner
    Battery Free memory backup
    Direct Access Tuning
    GE Universal Remote: Quality Metal face, lighted buttons works very well
    Motorized Volume Control - Via Universal Remote
    Audio Input: Phono, CD, Tape 1, Tape 2, Video 1, Video 2
    30 AM/FM Presets
    Impedance Selector: 8 ohm/4 ohms switch
    Speaker Connection: Clip-Lock ? A, B, A & B 4 & 8 Ohm
    Dimensions: 18" W x 13" D x 5 7/8" H (45 x 331 x 150mm)
    Weight: 20.9 lbs (9.5 kg) without packaging.
    Hooked up to MX-250 Cerwin Vegas which are 4 Ω. Does the receiver know the resistance or is there a way to select it? And what can I do to optimize the system?
    Onkyo TX-SV727 & Cerwin Vega MX-250
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    You have to go into the menu and switch it to 4ohm. It should be in the manual under impedance selector.
    Go here to download the manual from Onkyo.
    TX-SV727 Manual
    pitdogg2 Posts: 27,058
    edited January 2012
    dbayyz wrote: »
    FEATURES:
    THD: 0.08%
    30 AM/FM Presets
    Dude you got your answer in the other post you created!! Just hook them up and don't crank it. All speakers are NOMINALLY rated which means that even if it were 8ohm the speaker will dip lower into 4ohm on some material. 4ohm speakers will dip even lower into 2-3ohm on some material and it may even go to 6ohm. All those switches were put into place by UL labs to help keep your gear from catching fire through limiting the current to the speakers which won't help your speakers any they need current. If the onkyo keeps shutting down you'll need an AMP. plain and simply
