impedance question with bi-connections
I had a thought when it came to the bi-connections on the rear of my A9's. If you Bi-wire the speakers using a single amp vs Bi-amp using two amps, are you getting a different impedance load? Bi-Wiring is effectively wiring the high and low drivers in parallel. So if the A9's are rated 8ohm normally (with bridge plates) does that mean that the high frequency and low frequency drivers individual connections are rated at 16 ohms each? Or are the HF and LF 8 ohms and remain 8 ohms when connected? That would go against ohms law ...
Polk RTi A9, Polk CSi A6
Paradigm Sub, Side, Rears
Emotiva XPA-2, Pioneer Elite VSX-01TXH A/V 7.1
LG BD390C BR, LG 60PG60 Plasma
Hotaudio DAC Extacy
XPA-2/RTiA9 in Action
http://www.youtube.com/watch?v=-rtxxb2RIws
http://www.youtube.com/watch?v=bgWk-fCAooo
--vintage--
Sansui G-7500 Pure Power DC receiver
Sansui SP-X8000 4way/6driver speaker
Sansui SR-535 Turntable
Cerwin Vega AT-12 < Bud Beer
Post edited by tugzy on
wow, nobody?
Hotaudio DAC Extacy
--vintage--
Cerwin Vega AT-12 < Bud Beer -
The reason it is 8 ohms either way is due to the crossover. One set of binding posts goes through a high pass filter for the tweeter, while the other goes through a low pass filter for the woofer. When paralleled with the jumper, only the highs are going through one set, and only the lows are going through the other set. So, one posts impedance means nothing to the other. They're both only working with a certain set of frequencies.
the reason it is 8 ohms either way is due to the crossover. One set of binding posts goes through a high pass filter for the tweeter, while the other goes through a low pass filter for the woofer. When paralleled with the jumper, only the highs are going through one set, and only the lows are going through the other set. So, one posts impedance means nothing to the other. They're both only working with a certain set of frequencies.
+1
Polk RTi8
Polk Monitor 40
Polk CSi5
Polk MicroPro 2000
Visio 42 LCD
Denon AVR 790
Samsung BD 1600
Two Channel
Polk SDA 2B -
