ohm question
Ok, Heres the setup. I have 2 cs400i center channel speakers hooked up to my avr(denon 988). The cs400i is 8 ohms but with both hooked up what is my avr seeing(8 ohms,4 ohms or something different). I have a amp(adcom 5503)but haven't used it in about a month since I don't listen very loud. Should i be worried about damaging my avr.
Post edited by w_coyote on
No, you will be fine as long as all the speakers you use are the same impedence.2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
