RTi A9's and two Jamo Sub 300's?
xrapidx
Hi Guys
I'm currently running two RTi A9's of an Onkyo TX-NR807 system - this will by the end of the year be a full 5 or 7 speaker system.
Currently its in a very large room, but will move to a smaller room once the other speakers are purchased.
I was wondering if anyone had any experience running two Jamo Sub 300's with RTi A9's?
I use the system for a 50% movie/music split.
Thanks.
Thanks.
Post edited by xrapidx on
No experience with that sub, but for the price I would look at Epik subwoofers and go that route. Bang for buck it will probably dig deeper than the Jamo subs. Epik Empire is on sale right now also, www.epiksubwoofers.comShoot the jumper.....................BALLIN.............!!!!!
Wow - like the look of the discontinued Conquest Subwoofer - Weight: 200lbs.
EDIT: Can't seem to find a supplier here in South Africa. -
They don't ship to Africa but you can arrange for a pickup from there company using fedex or ups. -
check out www.svsound.com, they ship everywhere and offer excellent subs also. I had two shipped to me in Japan. I would suggest you check out the NSD-12 if the others are out of price range. Two of those should rock your room once you get it all set up.Shoot the jumper.....................BALLIN.............!!!!!
I'm not to worried about price - but obviously don't want to 'over' spec my system - I'll be sticking to the RTi series speakers for at least a couple of years.
So any recommendations appreciated.
The PB13U will match up perfectly with the 9s and rest of the system. Go for it, it's a killer sub. It does well with music and is a beast for HT.Shoot the jumper.....................BALLIN.............!!!!!
Been trying to find an easy way to get them here, but the shipping is almost the same price as the sub
Would anyone consider a 2nd hand Paradigm Servo-15 with these speakers, or is it past its sell by date
