Suggestions for budget phono cartridge
Zitro
Zitro Posts: 864
edited February 2010 in 2 Channel Audio
Hey guys, I have a question for you. I am very close to getting my TT set up and am very excited to have my own vinyl setup! However, I would like input from you guys for phono cartridges. I am looking for a good budget cartridge, less than $100 out the door. All arrows seem to be pointing to the Shure M97xE, which can be had for about $80 shipped, maybe less. However, before I pull the trigger on this cart, I wanted to know if there was something possibly better out there in the same price bracket. Associated equipment is a JA Michell GyroDec w/ Rega RB300 tonearm. Any input is appreciated, thanks!
- Jeremy
- Jeremy
Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
Speakers: Polk Monitor 7A's, KEF Reference 104aB
Sources: ProJect Debut Carbon, Sonos streaming FLAC
Post edited by Zitro on
  • thsmith
    thsmith Posts: 6,082
    call Needledoctor.com in the morning, tell them which TT and arm you have.
  • HB27
    HB27 Posts: 1,518
    http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=GRADBLKSTD
    I've got both and prefer the Grado Black std.
    Better range, smoother, and less $$$
  • PSOVLSK
    PSOVLSK Posts: 5,406
    I got the Shure M97xE a couple of weeks ago on Amazon for $60. I'm happy with it so far, especially for the price.
    Good advice from thsmith. I've found that he knows what he's talking about.
  • Zitro
    Zitro Posts: 864
    HB27 wrote: »
    The Grado was actually my second option. I couldn't find as much info on it as I could the Shure, but what I did find was definitely positive.
    I will give needledoctor a call tomorrow, thanks for the advice. Hopefully they don't try to steer me to a more expensive cart than i need just because they want a sale.
    - Jeremy
  • hearingimpared
    hearingimpared Posts: 21,136
    Zitro wrote: »
    A lot of good suggestions. They won't steer you into a more expensive cart. Tell them your budget and they will do right by you.
    mhardy6647 Posts: 35,328
    Shure M97xe and Grado Black are perennial favorites. The latter has some tt compatibility issues (google "Grado hum database" and "Grado dance") but a nice, lush sound (if that kind of thing is your bag; it is mine).
    Some recent chatter elsewhere suggested a few other house-branded options.
    http://www.audiokarma.org/forums/showthread.php?t=280738 check post #10, e.g.
    For the record (so to speak), I am not a big fan of virtually any of AudioTechnica's offerings. YMMV, though. They've certainly got cartridges at all price points.
  • jimmydep
    jimmydep Posts: 1,305
    I've been using the Shure M97xe for about 6 months now, It took about 40 to 60 hours to really break-in but now it sounds great. I haven't had the opportunity to demo many cartridges, but for $60 this was a good choice for me.
    Jimmy
  • timpeace
    timpeace Posts: 31
    Amazon.com has the M97xe all the time for around $60 with free shipping. I've had one on my Goldring gr1 (aka rega P2) for over a year and am extremely pleased with it. For the price you just can't go wrong.
  • bigred7078
    bigred7078 Posts: 477
    Quick question,
    Why are you wanting such a cheap cart on that excellent table/arm combo?
    Regardless, my vote is for Grado Black1
    Pro-ject RM-9.1 w/ Grado Sonata 1 -> USP-1 -> RPA-1 -> Vienna Acoustics Mozart Grands
    bigred7078 wrote: »
    Quick question,
    heh, I hadn't even noticed the hardware in the first post! :-( Good question... but, heck, it's easy enough to upgrade when circumstances permit.
  • Zitro
    Zitro Posts: 864
    bigred7078 wrote: »
    Quick question,
    My budget is quite limited right now. The Rega arm took most of the money I had to spend on this TT. The GyroDec is a gift, believe it or not, from a close friend who hasn't used it in years due to upgrading to a better table. Considering I also needed to buy a phono preamp and another pair of IC's, about $80 is all I have to spend on a cartridge. But...
    ...this is exactly what I plan on doing when funds permit. I will definitely upgrade the cart later and let this table/arm really do its thing :)
    - Jeremy
  • bigred7078
    Zitro wrote: »
    WOW, what an awesome gift! haha. Thats nuts, what a good friend. :D
    Definately make sure and save up for a great cart though, that table deserves greatness :D:cool: Enjoy:)
  • hearingimpared
    Zitro wrote: »
    - Jeremy
    I scanned your post so quickly I missed this. Nice TT and very decent tonearm. As mhardy said be careful with the Grado cart as they are finicky as to what tonearm they are attached to. If you call the Needle Doctor, or whom ever you choose to make the purchase, make sure you tell the rep what tonearm you are using so they can recommend one in your price range that is compatible with the 300.
    A DL-160 wouldn't be a ridiculous choice, albeit a bit pricier than the original budget.
  • Zitro
    Zitro Posts: 864
    Thanks guys. I will probably call NeedleDoctor shortly and I'll see what they tell me. Yeah, it is a very nice table and I am very lucky. My good friend is actually my girlfriend's Dad who is a huge hifi and analog nut. We're very close and he likes that we share this hobby; said he'd rather have someone else enjoying the table than it sitting stored away. He upgraded to a very nice Clearaudio some 5 or 6 years ago. He says I will never experience audio bliss until I get a dedicated analog setup, and based off of his rig I think he's right :cool:
    lol, yeah thats definitely out of my budget, and this isn't your fault since I forgot to specify, but my phono preamp only supports MM cartridges, so this would be a no-go either way.
    - Jeremy
  • hearingimpared
    Zitro wrote: »
    That's a kick the behind. However there are some really great sounding MM cartridges out there but they are out of your price range. At least you know for the future they are out there.
    Boy are you on a roll, free speakers, free turntable . . . great way to break into this hobby.
    Zitro wrote: »
    heh, I hear you on the budget... but the DL-160 is a HOMC (1.6 mV, if the web is to be believed) that's potentially amenable to your MM preamp :-) Just sayin' (otherwise I'd have suggested the venerable DL-103
    LOMC).
    Nice fellow your GF's Dad; that's a fine tt (as is the arm); sounds like you knew that already!
  • Zitro
    Zitro Posts: 864
    Yes, I considered this before purchasing the preamp (Cambridge Audio 540P) but for now mostly MM cartridges are whats in my budget, and I've been told they're easier for beginners anyways. And trust me, I know; I've been beyond lucky *knock on wood* and am incredibly grateful. I really love this hobby and couldn't do it on my own right now or any time soon so I'm just glad I've been fortunate to run into some very kind people. CP has helped a lot, and later on when I have more money to spend, there will definitely be some Karma-ing on my end going on :)
    - Jeremy
  • Zitro
    Zitro Posts: 864
    LOMC).
    Thanks; he actually gave me the stipulation that if I wanted the table I had to buy that particular arm or he wouldn't give it to me since it wouldn't be doing the table justice lol. He's a great friend and an even better man.
    - Jeremy
  • hearingimpared
    Zitro wrote: »
    You must be doing something right.:) Great attitude too!
  • madmax
    madmax Posts: 12,434
    Don't forget to look at used on Agon also. I've purchased at least 3 that way and could not tell the difference from new. Plus, I was able to resell for the same price later when I upgraded.
    madmax
    Vinyl, the final frontier...
  • hearingimpared
    If you go the agon route there is a thread somewhere here that has a cartridge/tonearm compatability formula chart or you can find one via Google.
  • Zitro
    Zitro Posts: 864
    Well, I called needledoctor and they actually recommended the Ortofon OM10 over the Shure, although he agreed the Shure was a good one. He found the Ortofon to be a more detailed cart. Anyone have experience with this cart? It's only $69, which is under the budget of about $80 that I gave him.
    - Jeremy
  • hearingimpared
    Zitro wrote: »
    Cool! I've heard of the Ortofon and remember reading a review on it but I've never heard one. Good luck and have fun with it.
  • Zitro
    Zitro Posts: 864
    Gracias sir :cool:
    I think I am going to go with the Ortofon OM 10 super phono cart, unless anyone gives me any reason to do otherwise.
    http://www.needledoctor.com/s.nl/it.A/id.274/.f?sc=2&category=402
    Here it is. Any last suggestions before I pull the trigger?
    - Jeremy
  • fbm211
    fbm211 Posts: 1,488
    lp gear might have better prices.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Zitro
    Zitro Posts: 864
    Ugh, got thrown a curveball...David (my girlfriends dad) just informed me that he has a cart he can lend me until I get my own...because my money is needed elsewhere since apparently the GyroDec has an issue with the power supply and won't power up. I have to get it fixed :( . Do you guys think a general electrician should be able to fix what it is? David has no idea what's wrong with it.
    - Jeremy
  • hearingimpared
    Zitro wrote: »
    Gracias sir :cool:
    That looks easy to set-up but one word of caution, DON'T WEAR LONG SLEEVES or be drinking before you do set it up. You don't want a bent stylus.
  • hearingimpared
    Zitro wrote: »
    UGH!!! I just saw this. Any electronics repair shop should be able to take care of it. You may also want to see if there is a mom & pop brick 'n mortar place around. They usually will work on problems like that and know just where to get the parts or service manuals right off-hand.
