RT600 vs RT35
hlalanne
what is the major Deference if any between the RT600 and the RT35.
speakers.
thanks
My sole purpose in life is simple to serve as a warning to others.
speakers.
thanks
Wooden Delight Theater
9/11
NEVER Forget !!!
9/11
NEVER Forget !!!
Post edited by hlalanne on
Cabinet volume, and therefore bass extension. Power handling capacity.....and a couple hundred bucks:D
the reason i was asking is that, I own a pair of RT35. and C.C. will give me a pair of RT600 for $300.00.
So I was wondering if I sould get them ? and replace my RT35's.Wooden Delight Theater
9/11
NEVER Forget !!! -
The RT35i's are excellent speakers. I listened to them but ended up buying the 55's because they'll play a little louder and go a little deeper in the bass. And for $400 I think they're a teriffic bargin.
As far as the 600's vs. 35's, though, it probably should come down to whether you would prefer bookshelf or floor-standing speakers. Performance wise, I don't think the difference would be worth $300 to me. But I've only heard the 600's at CC. -
If you want an improvement for your dollar... trade up fromt the 35's to the 55's... It will cost you a lot less and give you a whole lot more than the single driver can offer.. must my 2 cents...:cool:
I agree with Thomas, the RT55i's are by far the best speaker for the money since they're selling for $400.
Aaron
