what's a good single dvd player Ie:panasonic,onkyo,denon, or similiar
faster100
faster100 Posts: 6,124
edited May 2003 in Electronics
Just looking for idea's for an upgrade path for my dvd, I moved my older RCA 5 disk dvd to bedroom duty and bought a Pioneer dv250 from walmart, wanted to know if anyone knows this model or what other good models in the single tray dvd around 90-200 $$ price range, Thanks..... Not 250.00 not 500.00 but 90-200 ok maybe 250 at the very very most!!
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2003
    What features are you looking for? Built in DD/DTS processors?
    What type of video out's do you want?
    Cheers,
    Russ
  • PETERNG
    PETERNG Posts: 918
    edited May 2003
    How about the JVC 723, progessive scan, built-in DD DTS decoder, outputs for coaxial and optical. S video out and also plays DVD audio for 100 bucks?
  • faster100
    edited May 2003
    Well all of the above i suppose, S video out, digital coax and optical out, haven't really got into DVD-A but that would be a ++ so i could try that as my receiver has 5.1 audio inputs.. doesnt really have to be DD or DTS as my reciever does that but i would guess all the current models have that already anyways.. My TV isn't componet video compatable But my receiver is so that could also affect something down the road when/if we ever get a new T.V which i doubt will be anytime soon
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited May 2003
    can't find anything on a JVC 723?? where do you find this model??
    The jvc site doesnt show it nor does e-bay, is maybe the model number wrong
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dorokusai
    dorokusai Posts: 25,577
    edited May 2003
    Faster - This comment will come anyhow as far as DVD players go so here goes the link to Chroma Bug problem in DVD players:
    http://www.hometheaterhifi.com/volume_8_2/dvd-benchmark-special-report-chroma-bug-4-2001.html
    If you scroll towards the bottom, they recommend some players that do not have the Chroma Bug error, and Panasonic seems to be the only consistent manufacturer. I do not know any prices of the models listed, but the model numbers are there for your reference.
    There are many fine choices for players in your range, that to me still have an excellent picture.
  • dorokusai
    edited May 2003
    Actually here is the link to the recommended players by the website/ forum:
    http://www.hometheaterhifi.com/volume_8_2/dvd-benchmark-special-report-chroma-bug-4-2001-list.html
  • wlrandall
    wlrandall Posts: 440
    edited May 2003
    I've been extremely happy with the JVC XVS65, which was replaced by the 503. No jaggies, no chroma bug, no layer delays and the picture is simply stellar. Best $200 I ever spent on a player.
  • faster100
    edited May 2003
    cool link tHANKS, I was actually thinking the panny rp62 because i seen someone on here reccomend it,
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaN
    edited May 2003
    The JVC may be OOP, I bet Pete has one in his Magic Closet to sell on the cheap.
    (not the ORIGINAL magic closet by any means, but relative nontheless).
    I'll vouch for Pete too, stand up guy, takes GREAT care of his gear. Unless he makes a note, consider anything he sells as-new.
    Cheers,
    Rooster
  • shack
    shack Posts: 11,154
    edited May 2003
    I have the RP-62 and it is a fantastic DVD player. Not the heavest build quality but the eletonics are very good and I got it for ± $110 (and it may be cheaper now). Very good PQ in both progressive and interlaced.
  • faster100
    edited May 2003
    Shack,
    what outputs does it have?? I am really interested in one
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RSTERN
    RSTERN Posts: 287
    edited May 2003
    I also have the RP-62 and cd's sound better on it than my old cd player. As far as audio outputs: It has digital optical only, no coax, and analog. Video : S-video, component video and the single rca cable. hope this helps.
    Rob Stern
    mains: rt16
    center: csi40
    surrounds:fx 1000
    sub: SVS 20-39pc+
  • faster100
    edited May 2003
    I want digital coax and optical, damm
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • shack
    shack Posts: 11,154
    edited May 2003
  • shack
    shack Posts: 11,154
    edited May 2003
    The Optical does just fine.
  • faster100
    edited May 2003
    whats the deal with the sub out along with the analogs L/R ??
    why do they offer that, and so is this dvd-A ??
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Ceruleance
    Ceruleance Posts: 991
    edited May 2003
    I have it on my panasonic (sub out), but I have never used it. The player doesnt have DVD-A, nor does it do DD or DTS decoding, I think they just threw this in there to give you the option. Its not something I think many people with real home theatre systems use.
  • shack
    shack Posts: 11,154
    edited May 2003
    The analog outs and sub out is for someone using a stereo receiver or the analog stereo inputs on their TV (no digital processing). This way they can have stereo sound and have some bass. Remember, the majority of the people using a DVD player are not using any sort of processing ie: A/V reciever or pre/pro.
  • scottvamp
    scottvamp Posts: 3,277
    edited May 2003
    Nice call shack!!!
  • PETERNG
    PETERNG Posts: 918
    edited May 2003
    It's the JVC XV-D723, GOLD COLOR, DVD AUDIO/video PLAYER, PROGRESSIVE SCAN WITH REMOTE, top JVC player over a year ago, do a search in yahoo, great player, sit and collect dust in my magic closet, like the Russman said. I think the remote probably cost more than the player now.
