Replace passive radiator with active driver?
ANWKLO
ANWKLO Posts: 173
edited February 2010 in Vintage Speakers
Have you ever thought to replace the passive radiator with an active driver of Monitor 5 / 7? Is it viable without / with minor modification of the x-overs?
Excuse me for my silly question:)
Post edited by ANWKLO on
    treitz3 Posts: 20,117
    It is strongly not recommended.
    F1nut Posts: 51,997
    You don't want to do that. The cabinet is designed for use with a PR as is the crossover.
  • John in MA
    John in MA Posts: 1,010
    The passive radiator is essentially a variation on a tuned-port design. The cabinet isn't sized for another active driver.
    heiney9 Posts: 25,497
    NO, NO, NO and No..........won't work, won;t sound good, not designed that way. A passive radiator is essentially a port and is tuned to work with the active driver(s) to create lower octaves.
  • dorokusai
    dorokusai Posts: 25,576
    No reason and a PR is a fancy port.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I've never even felt a desire, or a need to replace the PR's in my Monitor 7's with active drivers.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • ANWKLO
    ANWKLO Posts: 173
    Oh yes. You are enlightened me:)
  • gdb
    gdb Posts: 6,012
    Monaco is also a fancy port.;)
