Schematics Review
dorokusai
dorokusai Posts: 25,577
edited February 2010 in The Clubhouse
If any of you folks, between chasing off newbies and getting into cable arguments, can take some time to browse the vintage loudspeaker schematics and let me know what you feel is missing?
I'm doing another round of PDF conversions and archive searching and in case I miss something, figured I'd ask membership for some help in identification.
Just post them here and I'll compile them. I'm only spending one day at HQ so we have a week to get a list together. If you have over 1000 posts, consider this your duty so to speak.
TIA - Mark
Post edited by dorokusai on
  • kcoc321
    kcoc321 Posts: 1,788
    In the "RTxxxi SERIES - VINTAGE"
    I have the RT55i schematic I got from Kim
    http://www.polkaudio.com/forums/attachment.php?attachmentid=46071&d=1264542407
    In the RTixxx SERIES - VINTAGE"
    I have the RTi70 schematic I also got from Kim (which surprisingly has been downloaded more than the RT55i version)
    http://www.polkaudio.com/forums/attachment.php?attachmentid=46073&d=1264561593
    "The want" list:
    >The RT35i would be nice as well.
    > A better copy of the LSi's would be nice. ( A few of them are hard to read)
    Also, I noticed the Monitor 30 schematic is in with the vintage Monitors.
  • dorokusai
    I fixed the M30 issue and added the other two schematics. Thanks!
    I'll look into the LSi problem.
  • Face
    Face Posts: 14,340
    For the LSi Schematics, Cont-Shift-+ will turn them the correct way.
  • dorokusai
    Yea, I just took a look at them and aside from me scanning a couple upside down, they look crisp to me. Just rotate them and print.
  • superjunior
    superjunior Posts: 1,632
    in the cs series I didn't see the csi a4 or a6 listed. also in the fx series didn't see the fxi a4 or a6.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • kcoc321
    It is the Lsi9 & the LSi25 schematics.
    LSi9: The values for the L1 and C1 are 'washed out and unreadable', both in the diagram and the table.
    Lsi25: All the values are hard to read. It must just be because of my 15" screen on my laptop.
    Since you are updating the the diagrams, it would be nice to be able to read them.
    It wasn't about the rotation, I can handle that.
  • dorokusai
    The RTiA series will not be posted.
  • dorokusai
    kcoc321 wrote: »
    The LSi9 is hard to read but the LSi25 is perfect. I'll try and get a better LSi9.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Hmm...we don't currently have any schematics up for the Peerless equipped Monitor's.
    I'm not sure about the Peerless 5's...The Peerless 7's were basically the same as the regular 7's, but with different resistors in the HF signal path. A 2.7 and a 4.5 ohm resistor was used instead of the 2.0 ohm resistor usually found in Monitor 7's.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • kcoc321
    dorokusai wrote: »
    Thanks, the LSi25 must be my crappy little laptop monitor
    +1 for the Peerless Monitor Series...That would be sweet :D
    In the CS series, the CSi5 is missing....
  • dorokusai
    I'll double check but I found most of what was available for the vintage Monitor series.
  • amulford
    amulford Posts: 5,020
    Nice job you are doing, here is my wish list:
    RTxxxp series -
    RT3000p satellite wiring (you do have the sub)
    RT3000p sub amplifier schematic
    RT2000p amplifier schematic
  • piper
    piper Posts: 41
    How about cut-away drawings / plans for the f/x1000 speaker.
    Many are wanting a set, and very few are available.
    Perhaps the more adventurous would enjoy a chance to build a set ?
    Thank you.
  • dorokusai
    piper wrote: »
    Thank you.
    No, I'm sorry but that won't be posted.
    Toolfan66 Posts: 17,210
    dorokusai wrote: »
    the rtia series will not be posted.
    why??:(
  • dorokusai
    It just isn't going to happen, pretty simple.
