Crossover Question
Murray1
Murray1 Posts: 193
edited February 2010 in Speakers
Just picked up my new Hsu sub and need to know what I should set my crossovers at. I have RTiA5's up front with a CSiA6 center. No rears or surrounds. Before I got the sub, I had the L/R set to Large and the C set at 80. Need to know what settings I should be using now that I have a sub in the mix.
Post edited by Murray1 on
  • pearsall001
    pearsall001 Posts: 5,290
    Murray1 wrote: »
    To start off, set them all to small & 80hz. Then play around with the mains at 70 then 60 to see what sounds best. The center should be left at 80 & whatever sounds best to you for the mains (80/70/60). Don't forget that proper sub integration is key in achieving a well balanced, seemless front soundstage.
  • Murray1
    Murray1 Posts: 193
    My HK 3600 avr does not have a small choice. Only choice is Large, 40,60,80,100,etc. I am assuming when I choose 80, the speakers are being set to small. Yes???? My new Hsu sub is the more powerful model. What do I gain by using lower that 80 for the mains. Why should I leave the C at 80. Think I have an idea but want to hear from the pros. Thanks for all your help.
  • pearsall001
    Murray1 wrote: »
    Here's a great article that might answer your questions...http://forum.ecoustics.com/bbs/messages/34579/128214.html. As far as your AVR not having a small setting, I'm assuming that 80hz would default them to the small setting. I'm guessing here though. Let you ears be your guide, nothing's set in stone as far as the settings go but the THX pros all recommend the small setting at 80hz for all the speakers in a surround system.
