G35 Audio Upgrade
Bauer418
Bauer418 Posts: 1
edited February 2010 in Car Audio & Electronics
Hey guys,
I'm finally doing some work to my G35 and the first thing I wanted to change was the audio system. I already changed out the head unit to a Pioneer AVIC-X910BT, and I'm looking at the rest of the system. I already ordered the Rockford Fosgate P400-4 amp which is 100Wx4 RMS @ 2 ohms and now I'm looking at speakers. I'm thinking about doing the MM6501 in the front and MM521 in the rear. Anyone with this combo have comments on how it sounds or configuration suggestions?
Just looking for some insight.
Post edited by Bauer418 on
  • arun1963
    arun1963 Posts: 1,797
    I'd do fronts + sub, powered off the amp. No rears. If you still want a set at the back, then the mm521 at the back, running off your hu would be fine.
    The mm's would present a 2.7ohm load to the amp and get about 90 watts each. Which would be fine. Bridge a DVC sub across the amps rear channels and the sub would get 200 watts.
