Bash or Dayton?
mhmacw
What's better in the 500w? Who makes the better amp? Always a pleasure. Thanks, Dan
Post edited by mhmacw on
BASH is a type of AMP. Dayton is a brand...
so who makes the bash amp?
I wouldn't be surprised if Dayton did....
All kinds of manufacturers make them... If you need me to search the interbutts for you, i will.
concealer404 wrote: »I wouldn't be surprised if Dayton did....
the one i am referring to is the one pe has. but now i see its out of stock so. what about a monoblock for my sub? does that work? -
Dayton! 2x sa240 plate, 1x easub2-5m. if that dont get that dvc moving i dont know what will.
I have used both with positive results.
thats good to hear. two of them bad boys ought to do the trick eh?haha
I am using a Dayton 240 right now in a sealed s 15" sub with a kicker comp and it sounds awesome, bass it tight and deep.
right on man. i just built a 4.4 cubic foot box with a ma audio dvc 15". just got 2 of those 240daytons one for each coil. i also picked up a energy 10.3. i dont think ill be short on bass. i think ill get a switch to compare sbs.
Speaking of.... Did you ever post pics of your final design for that MA sub, and what did you finally go with on the port set up??Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
ya man theres a few of the cut and screw stage i think they are in thre post in (speakers forum) custom sub enclosure. i think. but i havent put the amps in or finished it yet so no final pic but theyre coming. i went with (2) 4x14 inch ports. it should be a home shaker. im seriously thinking of putting it in the basement now and only showing the 10.3. that would be a suprise eh hahaha. also i need to find 4 inch spikes so i may wind up building or turning those myself.
I personally have 2 Dayton 10" active enclosures and really like them. I am experimenting with a heavier duty woofer in said enclosures. The amps are great and no current problems to date.
BTW, I'm new to the Polk forum and look forward to sharing thoughts and views. -
hearingdoc wrote: »I personally have 2 Dayton 10" active enclosures and really like them. I am experimenting with a heavier duty woofer in said enclosures. The amps are great and no current problems to date.
there are lots of thoughts and views here. a wealth of knowledge to be had. good luck in your audio ventures and welcome to the club! -
^ Thanks for the welcome!
