silver vs silk
hawkshaw
hawkshaw Posts: 1
edited February 2010 in Forum Testing Area
new member,have a pair of sda-1cs with a bad silver coil dome tweeter. saw info on internet about changing out to silk dome and upgrading caps. called polk 60.00 for either silver or silk.anybody with used silk domes four needed.also no manual listed at polk audio for sda-1cs, will need schematic of crossovers to change out caps.name and number of best caps.thanks for any help or info.
Post edited by hawkshaw on
  • cincycat13
    cincycat13 Posts: 887
    http://www.polkaudio.com/forums/showthread.php?t=55888
    follow the link to pdf diagrams. ask around in the vintage speaker area for tweeter opinions. will also get cap ideas such as sonicap seems popular. also, if you mention to polk when you call, you may get a discount for being a forum member. welcome and good luck!
    heiney9 Posts: 25,548
    hawkshaw wrote: »
    The RD0194-1 is the part number for the replacement silk dome tweeter which replaces the "silver" dome sl2000. Not sure who you talked to at Polk but the "silver dome" sl2000 hasn't been avail for atleast 6-7 years.
    If you order the RD0194-1's tell them you are a Club Polk member and you will get a discount..........last I heard they would run you $45 a piece.
    They are highly, highly recommended and you need to replace all the tweeters if you go with the RD0194-1 as they will not sound right used together with the sl2000.
    Your other option if you wanted to save money is post a wanted to buy in the classifieds for a used sl2000
    http://www.polkaudio.com/forums/forumdisplay.php?f=33
    or try to source a 'used' one on Ebay
