Separates
avphile
avphile Posts: 38
edited February 2010 in Electronics
I am looking at buying an amp. I have narrowed my choices to Parasound and Sunfire. Does either require a 20A line? Also I see that the Sunfire TGA5200/7200 came out for only a year before it was replaced by the TGA5201/7201. Were there issues with the 5200/7200 series?
Post edited by avphile on
  • cfrizz
    cfrizz Posts: 13,415
    A 20A line is not reuired.
  • danz1906
    danz1906 Posts: 5,144
    Which Parasound amp are you interested in???
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • jinjuku
    jinjuku Posts: 1,523
    Depending on how easy/hard it is to pull a line I say why not. I pulled an additional 12/2 and terminated to a double gang outlet. I will run both my Adcom and Behringer EP2500 off of it. The rest will go on the circuit that was already there.
    You don't need to but if it is easy enough it's nice to know that you have a dedicated circuit that you can install other components on.
  • thuffman03
    thuffman03 Posts: 1,325
    cfrizz wrote: »
    Like he said it is not required but I would recommend a dedicated one. I have two Sunfire 300~2 running off of a 15a and when the music is jamming the lights are dimming.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
    nooshinjohn Posts: 25,918
    No issues at all with the 5200/7200. The reason for the change was to update the cosmetics to match the new TGP-401.
    Personally, I would look for a Cinema Grand Signature 5x400 as they run about the same price as the newer TGA5200 does and you will get a better looking amp with twice the power.
