Gfa-555
acmf74
acmf74 Posts: 937
edited February 2010 in Speakers
Would a Adcom GFA-555 that is rated 325wpc @ 4ohms be too much for the LSi15's? Thanks..
Post edited by acmf74 on
    heiney9 Posts: 25,530
    No, not at all.
    Go for it
  • acmf74
    acmf74 Posts: 937
    I have 265wpc @4 ohms right now into them and they sound great. I was thinking of stepping up my game a little..
    acmf74 wrote: »
    Don't get caught up with strictly specs. I have 30wpc and it far out performs anything else I have ever owned regardless of wattage.
    Good luck
  • ben62670
    ben62670 Posts: 15,969
    GFA stands for Great Friggen Amp
    Ben
  • Lowell_M
    Lowell_M Posts: 1,660
    I'm runnin one on mine every day. Never breaks a sweat and the 15's love it.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • lmacmil
    lmacmil Posts: 122
    acmf74 wrote: »
    If it's additional volume you are after, there's no audible difference between 265w and 325w. It will be less than one db.
  • acmf74
    acmf74 Posts: 937
    I hear the GFA 555 original is the best sounding version. What is the difference between the original and the newer one?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    acmf74 wrote: »
    Here ya go...
    http://www.polkaudio.com/forums/showthread.php?t=53981
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • danz1906
    danz1906 Posts: 5,144
    ben62670 wrote: »
    That's a good-1!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • starkiller
    starkiller Posts: 2,723
    I read that the 555 with the rack handles is the way to go....true??
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • Mauskar
    Mauskar Posts: 104
    Wait, I thought the GFA 555 puts out 200 wpc??? I have them connected to RTi10's...
    Mauskar wrote: »
    @8 ohms............why, who cares?
  • Mauskar
    Mauskar Posts: 104
    Just wanted to know. Is it possible to wire them into a 4ohm load on my RTi10's?
  • comfortablycurt
    Mauskar wrote: »
    Why? It's not like they'd be louder at 4 ohms or anything like that. It would just be presenting itself to the amp differently.
