rt10 or tsi200?
edited February 2010 in Speakers
I am currently running rt10's as my front speakers, but i found a set of tsi200's for a good price. Would they be an upgrade? thanks....
50" samsung dlp
receiver... pioneer elite vsx72txv
front... polk tsi400's
rear surrounds... polk tsi100's
center... polk csi3
subs... psw150..... 2 of them.
surrounds.....polk owm3's
Post edited by gsxr141 on
    Not sure if it would be an upgrade or not to be honest. I have never heard either of the ones you have mentioned, although I have just recently gotten my hands on a pair of TSi 500's on demo. I know they are completely different speakers, but in the same line so I would assume they would have about the same "sound" I'll say that I am impressed with the 500's so far, and will be doing an extensive A/B with my Monitor 70's soon. Back to your original question though, the RT10's have one mid/woofer (7 1/2") and the TSi's have 2 (5 1/4") The TSi's have a better overall frequency range (43-25KHz) as opposed to the RT's 30Hz - 25kHz. The RT's have a better Lower -3dB Limit (42) as opposed to the TSi's 50Hz. Upper -3dB Limit is about the same for both, as is recommended amplifier power. The RT10's are nearly twice the size of the 200's and weigh almost 4 times as much. All the technical mumbo jumbo aside, I have no idea how this relates to how they sound, so if you can go to your local BB and see if you can listen to them, they should have them in stock on the floor. If not, try Huppins or another HiFi store nearby. The TSi's are Polk's newest release and are still pretty easy to find in stores. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
Welcome!
Welcome!
