DSW Pro 500
sageleo
sageleo Posts: 170
edited February 2010 in Speakers
I'm really thinking about upgrading my sub. I'm currently using a PSW10, and I can honestly say that I'm not that impressed. It distorts easily and doesn't seem to have much power compared to the DSW line. I'm thinking about going with the DSW pro 500, since money is kind of tight the price for this is just right. I mainly use my set up for 80% HT and 20% music and gaming. Any help is appreciated.
Thanks,
Dirk
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • coolsax
    coolsax Posts: 1,826
    being on a budget you might also want to consider the PSW 505 that newegg has for 250.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • domflane
    domflane Posts: 653
    Polk Direct on ebay just listed a ton of refurb items for sale, there's lots of subs there. I would definately upgrade that PSW10, either the 505 or the 500 will do fine for the money.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
