rdo-194 or 198???
tonyr1
what tweeter should I use for monitor 10"s? rdo-194 or rdo-198? thanks!
Post edited by tonyr1 on
What tweeter is installed? Pop it out and look on the back. Hopefully we're not talking about a Peerless era tweeter.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
sl2000
rdo 194 is the replacement for your model tweeter.JC approves....he told me so. (F-1 nut)
george daniel wrote: »rdo 194 is the replacement for your model tweeter.
Yes. Mention you are a Club Polk member to get the discount.
Ben -
48 dollars instead of 60....sweeeeeet!:D
now I need to know what size poly switches to use. there is no markings on mine, but there are a bunch of different ones listed at parts express. when I called polk they said they did'nt have any. -
after reading about the poly switches on here I think I will just put a .5 ohm resistor in there. I recently bought an Adcom 555 to run the 10's but I'm using an old harman kardon pm665 as a pre until I can afford the Adcom 750 pre-amp. I think that should provide enough clean power to forget about the poly swithches.
Please tell me if I'm wrong! I do tend to crank the volume sometimes -
You should be fine. I ran a 545 for years and even when the distortion lights flickered a tiny bit, I never tripped a poly. As long as you don't get stupid you should be fine.
in my best Forest Gump: Stupid is as Stupid does.
Why are you putting a .5 ohm resistor there? Just wondering.
To compensate from the resistance lost from removing the polyswitch.Why are you putting a .5 ohm resistor there? Just wondering.
madmax"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
My Model 10's are from 1977. How are the various models identified? Would those be "Peerless era tweeters?" If so, what is the correct model replacement for them?-;-)
Model 10 since 1977
Mini Monitor II since 1981
Model 5 since 2010
PSW50 since 2008 (Just what the Mini Monitors needed!)
