Jonesing for an upgrade...
packetjones
packetjones Posts: 1,059
edited February 2010 in The Clubhouse
Well my small bonus check finally came in and I have $700 to spend on my HT setup. i am not sure exactly what i want to do with the cash so thought i would ask around here to get some opinions on what others would do. Currently I am looking at either a new subwoofer, an external amp, a BDP, or a combination of these. Based on my system what would everyone recommend and why?
I was leaning towards a SVS pc12-nsd, but this is almost the entire budget that I have. I then thought about maybe an ED A2-300 and an amp. What do you guys think? My current system is the speakers in my sig along with a HK 254. I would say that i am about 50% TV, 30% music and 20% movies. The room is approx 13x20 with standard ceilings.
Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
Post edited by packetjones on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Buy everyone from Club Polk a CD or record of their choice.:p;)
    You should always try to upgrade your weakest link. What aspects of your system do you want to improve?
    One thing I'd consider, is upgrading your CSiA4 to a CSiA6. That will make a BIG improvement in your sound. You'd still have a good chunk leftover, plus you'd be able to sell the A4 and recoup some of the cost of the A6.
    A new subwoofer would make a big difference too. The PSW110 is a decent sub, but it does leave a bit to be desired.
    I'd say your money would be best spent on a center channel and a sub.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • packetjones
    I would like to upgrade to the A6 but it will not fit in the cabinet that i have now. I would need to get a new entertainment stand and the wife would not really approve of that. The A4 fits perfectly in what I have now so it will be a while before i can get a new center.
    I think a sub is happening for sure. I am just torn between using the entire budget on a new sub or if I should go 50/50 with a sub and a mulitchannel amp. Something like a used adcom or carver would be nice. The HK i have now is rated at 50 wpc so it is not that powerful at all. Even a 100 wpc amp would be a big step up in that regards as well.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • comfortablycurt
    Well, the RTi series is pretty efficient, and doesn't really require a lot of power to sing.
    Do you use your equipment mostly for HT, or do you do any 2 channel listening on it?
    If you do a lot of 2 channel listening, you might want to consider just getting a nice 2 channel amp, and let your AVR run the rest of your speakers. The rest of your speakers will have a bit more breathing room too, if you let an external amp power the front two.
    An Adcom GFA-545 sounds great with RTi's...I've run both my old RTi8's, and my RTi6's off of my 545, with great results. The 545 can be had for $150-$200 on average.
  • halo71
    halo71 Posts: 4,632
    Just my .02, but I would look at the used market. I have been seeing a bunch of deals on my local Craigslist. But I am broker than hell atm...so all I can do is look.
    Like these examples
    http://atlanta.craigslist.org/atl/ele/1590514768.html
    http://atlanta.craigslist.org/sat/ele/1593633430.html
    --Gary--
  • packetjones
    I am intereseted in the used market for the amp. I have looked through the craigslist ad's in my area and there is nothing there. I guess there is not much of a market in oklahoma. i have looked through audiogon and the for sale section here. I know if i am patient then i will find a good deal.
    Looking for other opinions on what others think would be the best investment. Should I use all of the budget on a very good sub or should i step down to a lower sub and get an amp as well. Would the investment in an amp be a substantial upgrade from the AVR that i have. Enough to out way the difference in quality of the sub? All opnions are welcome.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • concealer404
    concealer404 Posts: 7,440
    If you're an HT guy, blow the whole budget on a sub. :D
  • thsmith
    thsmith Posts: 6,082
    If HT is the most important then a sub, if music then an AMP ideally tube.
    Does your HK have preouts ?
  • domflane
    domflane Posts: 653
    He has preouts, so I would suggest an amp. Mulitchannel is a good idea considering what you use your rig for. I have the HK354, which is 75wpc and I couldn't believe the difference my 80wpc Carver AV505 made, especially in stereo mode. My amp was $300, and there are other 3 and 5 channel deals out there from other companies for the same price or less. This would still leave you with a decent amount of money to buy a sub, which is what I would look into next. Theres a 10" Sunfire for sale in the classifieds for around $500, so thats where I would start. Good luck and enjoy your new gear.
    Dominic
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • Sherardp
    Sherardp Posts: 8,038
    +1 for the sub upgrade. Also check out Epik's new Empire sub.
  • McLoki
    McLoki Posts: 5,231
    Sound treatments (ATS Acoustics is a good choice, but there are many others as well)
    If sound treatments don't float your boat - spend the lot on a great sub.
