Suggest a cheap DIY preamp project
Sami
Sami Posts: 4,634
edited February 2010 in DIY, Mods & Tweaks
Simple, SISO preferably, cheap. No chassis necessary, just the insides, I plan to put it in a wooden box. Something one with limited EE knowledge will be able to do. I intend to use this as a stepping stone to a more demanding project so it does not need to be sonically great, cheap and mediocre will do.
  • Wardsweb
    Wardsweb Posts: 944
    This is very simple. A Bottlehead battery powered pre. You won't get the wood cabinet. It does come with the chassis plate (acrylic) and all the parts to build for $99. It comes with a black knob, I used an aluminum one I had.
    The PCB is an upgrade option ($35).
  • ben62670
    ben62670 Posts: 15,969
    Grounded Grid tube pre.
    Edit:WW very nice chassis.
    Ben
  • bikerboy
    bikerboy Posts: 1,241
    I ordered a LDR preamp kit from http://www.buildanamp.com/
    http://diyaudioprojects.com/Solid/DIY-Lightspeed-Passive-Attenuator/
    The matched LDRs and boards should be here soon. I'll let you know how it works out.
    The bottlehead is one I have looked at many times. Nice work Wardsweb.
    DIY is fun. Makes use of many skills.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • ben62670
    Thanks for the linky BB. I have been wanting to add the LDR attenuator to my pre for some time now.
    Ben
    Ben
    mhardy6647 Posts: 35,534
    another vote for the Grounded Grid:
    http://www.transcendentsound.com/preampkit.htm
  • ben62670
    I am running the Grounded Grid right now. Very pleased with the results. It is paint by numbers style.
    Ben
    Ben
  • strider
    strider Posts: 2,568
    bikerboy wrote: »
    Aren't the LDRs finicky in regards to input and output impedances of the amp and sources used with it?
    Wristwatch--->Crisco
    ben62670 wrote: »
    Ben
    I am a ditz, neglecting to notice that the OP was asking for DIY. Sorry :-P
    Did you peruse Pete Millett's site? He might have some good ideas.
    I have used his original hybrid, low-voltage space-charge tube headphone amp also as a preamp and thought it sounded very good.
    Pete is an outstanding resource for us DIYers, especially for his outrageous collection of scanned (ex-copyright) technical resources online.
    www.pmillett.com
    http://www.pmillett.com/technical_books_online.htm
    http://www.pmillett.com/tube_data.htm
  • strider
    Another thought is the PassDIY B1. It's an impedance buffer with no gain and a pretty simple circuit to boot. There's always a group buy going on DIYAudio.com for PCBs, and the guys over there are pretty helpful when your stuck, especially if you put the effort in first.
    That Bottlehead kit does look really simple, however, and I'd bet the support would be much better then with the B1.
  • bikerboy
    Strider-All passive preamps have to be matched as far as impedence. The kit I ordered claims to have provisions built-in to deal with that. So I'll see how well it works with the jolida. It should be here soon. The B1 seems to be a common solution with a standard LDR preamp.
    Bottlehead Eros
    CD: DIY Shigaclone
