Atrium 8 Outdoor Speaker
dak54
dak54 Posts: 3
edited February 2010 in Speakers
I'm planning to purchase the dual coil Atrium 8SDI for a large (300 sq. ft) deck. The speaker will be part of my A-Bus (Russound) system and will be powered by 15w amplifier. Is this enough power for the Atrium 8 or do I need to boost the power?
Post edited by dak54 on
    treitz3 Posts: 20,012
    Hello and welcome to the forum. I would recommend boosting the power with good, clean power.
  • dak54
    dak54 Posts: 3
    What size amp would you recommend
    What might your budget be and how long of a run do you have to get to the speakers?
  • dak54
    dak54 Posts: 3
    The run from the present 15w amp is about 25 feet and to complicate matters, I've got two outdoor speakers coming off that amp.
    I'd be willing to spend +/-$200. What do you suggest?
  • dorokusai
    dorokusai Posts: 25,576
    Just run them with what you have for now, upgrade later. They're pretty efficient but I don't believe they will get very loud @ 15wpc.
    Wait, do you mean two pairs of outdoor speakers? If so, check out Craigslist and grab an older HT receiver with A+B speaker outputs.
