Sony vplaw15 hd-- dalite !)*" pull down
mhmacw
im trying to make a deal as we speak and would like any help on the value of this unit supposed to have 1.5 years left on warrenty of projector and screen. bulb included
Post edited by mhmacw on
I would say around 800-1000K. The projector is a 720p unit and the screen depending on material will reflect price. Most pulldowns are inexpensive so I'm guessing screen is roughly 200-300 price range. How many hours on the current lamp? You mentioned bulb included, but is it secondary? Regardless I would stick to the price I mentioned, especially when 1080p units (now at $999.00) , and screens are inexpensive.Shoot the jumper.....................BALLIN.............!!!!!
as i understand it there is another bulb in the box and thats about alliknow it looks like i am in a deal with the felow for 10 days hunting on my place for his entire theatre. heres the cl link see what you think of the quality as im not familiar with the sony stuff but i fugured i could ebay that stuff and get a good screen?
http://peoria.craigslist.org/ele/1587899308.html -
All that for 1200? Definitely worth it. Keep what you need out of the deal and sell the other stuff. The PJ alone is worth 600-700. The only thing I saw on it was the PJ is a little dim, but that's the case with most Sony PJ's anyway.Shoot the jumper.....................BALLIN.............!!!!!
my room is 16' on the long wall so the dim ness wont be too bad will it? also what do you know about the enery sub? never heard or them. so a couple days hunting with him is a good deal? i thought so too. you just never know ...might even make a friend. stranger things have happened eh? 5thanks for the info man its a great help.
@ 16' I think you should be ok at that distance. The sub is an Energy S10.3 which has a 10" driver. Not knowing what you have now, if you have a need for the sub then give it a shot. I think you will like the PJ and screen once you get it setup. Throw some HD material at it and enjoy the "Bigger" picture. GL and enjoy the hunting bro.Shoot the jumper.....................BALLIN.............!!!!!
looks like i made the trade. 5 weekends for that list. knowing nothing about the pj as of yet. what should i look for as far as functionability? tells of damage or anything to check? the components i can fumble through but the screen and proj are an unknown to me.
